Tip & How-To about Whirlpool LSR8233J
How to replace the drive pump on Whirlpool top load (diagrams for models Ls8233)
Hi.
If you are talking about the drive pump, this is located at the bottom of the machine, and accessing it is quite easy.
As a first thing disconnect the power cord, disconnect water lines and drain hose, and move the machine in a place where you can comfortably lean the machine on one side and support it to access the bottom of the appliance, where the pump is located. Also ensure that there is no water inside the machine before proceeding. If there is water inside the tub you will need to disconnect hose from the pump and collect water with a container while performing the procedure below.
Carefully tilt the machine and lay it down on its back. This is probably the most difficult part of the procedure, ensure that the machine is supported properly and start removing the two spring clamps that hold the pump and the two inlet and outlet hoses connected to the pump together.
Remove the two metal clips that hold the pump to the motor housing.
Slide off the pump and remove it.
Do all the operations described above in reverse order to install the new pump.
Before replacing the pump, ensure that the problem is not related to the hoses connected to the pump. Leaks and blockage problems are often caused by one of the hoses, rather than by the pump.
The pump is indicated with the arrow on diagram below, near to parts 30, 31 and 32. the clips are parts 30 and 31. The corrugated drain hose going to the tub is part number 32:
Regards.
Washing Machines Logo
Hi,My daughters washing machine (Hoover Nextra HNL 842) fails to empty after washing cycle.(error code 3). I intend to check the pump and float switch.I can access the pump through the bottom of the machine but cant see the switch.If it is the float switch do I need to remove the complete works for access? Thanks.
You should have a drain filter. They do become clogged and need to be cleaned out. If the draine filter is clogged you will immediately know it upon removal and inspection. If this is the culprit, be sure to show your daughter how to access it, remove and clean it and then to reinstall it. This can be quite frequent (8 to 12 months) depending on her environment, like allot of pet hair and things like that. Let me know if this is the culprit. By the way, you are going to have to bail as much water out of the drum as posible unless your model has an easy water shut off just prior to the filter. Otherwise, all the water left in the drum will run out of the filter assembly when you remove it. With any luck the filter is the culprit and not the pump.
Nov 21, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
f21, 5d, and not working
remove the bottom panel 3 scres and you will see it check the filter there for a blockage
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
wd865 spinning problems
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Mar 04, 2009 | Hotpoint Ultima WF865 Front Load Washer
How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
Sep 02, 2008 | LG WM-2277HW Front Load Washer
washer instructions need manual
You have a clogged pump.Find access to inside the machine,locate the pump and clean it out.
May 24, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
1,738 people viewed this tip
Sal De
Gerry Harvey
Gerry Harvey
