Tip & How-To about Miele WT945 Front Load Washer / Dryer
Miele WT945 Dryer Problems - Stage 3/4 fix
STAGE 3: THE ‘PROPER’ FIX (4 hours)
Unfortunately, if you want to go further the next stage of disassembly is horribly inaccessible. The Miele man rated it as probably the most difficult job on the machine, but said it was feasible and that he would personally undertake it if it was his machine rather than move to Stage 4. The challenge is to get the fan box itself off, which extends deep down into the rear of the machine where it eventually plugs into the back of the drum. And the back panel of the machine does not come off or swing out like the front does – the back and the sides are one piece of sheet metal. So you’re stuck with manipulating the thing at arm’s length in a very narrow gap, and to add to the fun there are some very sharp edges down there.
I've now personally done this job - it's a two-person task, took us around 4 hours but is feasible.
So (omitting some of the obvious smaller tasks like disconnecting wires and cable ties as needed), in addition to Stage 2 disassembly:
- undo a further Torx bolt holding the fan box to the drum, just to the left of the outlet hole you worked on in Stage 2, and loosen another bolt near the motor which holds a slot in the fan box casing to the drum
- remove the fan motor (held by two bolts, one low and invisible on its mounting bracket)
- remove the fan box's air inlet from the hole in the back of the drum that it slots into. This is right at the bottom of the fan box and thus very inaccessible. Eventually I found a long piece of sturdy wood (around 4 x 1cm section) could be poked down to this point (between the rear of the drum and the front of the fan box) and then gently pulled forward to lever out the air inlet.
- using Corbin-type pliers on the clips, remove the four hoses that connect to the fan box (best to do this once the air inlet is free from the previous step, as you can then lift the fan box up a little with the hoses still connected, which makes access to the clips a lot easier.
- remove the fan box from the machine, and unscrew the Torx screws holding the white plastic cover (which includes the condensor unit) to the metal casing. Go very carefully here - corrosion can cause stiff and maybe sheared screws. Best to soak the screws with WD40 beforehand where they thread into the metal casing.
- remove the fan rotor by undoing the nyloc nut on the shaft. It (the rotor) is a tight fit on the shaft and may need some gentle encouragement with a hammer. Pause again to be amazed at the amount of fluff. Clean everything out fully (fan rotor, metal fan housing, white plastic cover/condensor unit, black rubber strip which seals the two halves of the fanbox together, hole at the rear of the drum which the air inlet plugs into.
- replace the plastic cover using some fresh silicone sealant around the edge, on top of the black rubber strip, to make it watertight.
- reassemble everything in reverse order. When it comes to reinserting the air inlet to the back of the drum, wet the inlet and the rubber gasket with copious soapy water. Even so the fit is very stiff indeed - just pushing with a thumb from the rear will not work. Solution: remove the white plastic cap from the inspection hole on the rear panel. Find a sturdy short cylindrical object (a large spark plug socket from a socket set is ideal) which will fit through this hole and press on the bottom of the fan box acting as a drift. Then rig up a lever (perhaps a horizontal wooden batten levering against a door frame) which will allow you to exert controlled pressure (a lot of it!) on the drift. Pack another wooden batten down the front of the drum to lock it in place, otherwise you will be wasting effort pushing the drum forward against its springs. You should feel the inlet push back into place. Look down from the top with a torch - if you can still see the sharp flange around the inlet tube, it's not pressed home enough.
STAGE 4: THE OFFICIAL MIELE FIX – FOR INFORMATION.
Miele technicians will only replace the fan box, not open, clean and refit it as described above. So the ‘official’ fix is to pay the callout charge, plus the infamous £400 for a new fan box,
Miele WT945 Front Load Washer / Dryer Logo
please confirm torque for 95 accent 1.5 head bolts.Thanks
Already answered on Fixya
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Cylinder head torque settings for 1995 hyundai accent 1 5
Feb 02, 2017 | Hyundai Accent Cars & Trucks
Torque setting for rear hub nut
stage 1 120 nm
stage 2 slacken off
stage 3 20nm +80 Degrees
stage 4 adjust further for splitpin alignment
hope this helps Coloneus
Mar 07, 2016 | 2008 Opel Corsa 1.7
Hi I need the torque settings for both the cylinder head and the bottom end bearings for a 1997 Toyota Prado (3.4litre petrol). Thanks
1997 Toyota Prado 5VZ-FE
Cylinder head bolts:
Tighten the cylinder head bolts in criss cross manner inside out, in four stages as under:
Stage 1. Torque the bolts up to 17 Nm.
Stage 2. 34 Nm.
Stage 3. Rotate all the bolts 90 degrees.
Stage 4. Finally rotate all the bolts further 90 degrees.
Main Bearings:
Tighten the main bearing bolts in two stages, as under:
Stage 1. 61 Nm.
Stage 2. Rotate the bolts further 90 degrees.
Big end bearings:
Tighten the big end bolt of connecting rods in two stages as under:
Stage 1. 25 Nm.
Feb 27, 2014 | Toyota Land Cruiser Cars & Trucks
cylinder head torque specs for opel corsa 8valve 1.4l 2005 model
Corsa 1.4I Engine code Z14XE 2000-2004
Bolts must be renewed
stage 1. 25Nm
stage 2, + 90 degrees
stage 3. + 90 degrees
stage 4. +90 degrees
stage 5. + 45 degrees
Sequence
10 6 2 3 7
9 5 1 4 8
bolts 7 & 8 are nearest to the flywheel side of the engine
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. + 60 degrees
stage 3. +60 degrees
stage 4. + 60 degrees
Sequence as above.
stage 1. 25Nm
Sequence
10 6 2 3 7
9 5 1 4 8
Stage 1. 25Nm
Sequence as above. <br />Corsa 1.4I Engine code Z14XE <b>2000-2004</b><br />Bolts must be renewed<br />stage 1. 25Nm<br />stage 2, + 90 degrees<br />stage 3. + 90 degrees<br />stage 4. +90 degrees<br />stage 5. + 45 degrees<br />Sequence<br />10 6 2 3 7<br />9 5 1 4 8<br />bolts 7 & 8 are nearest to the flywheel side of the engine<br />Engine code C14NZ <b>1993-1998</b><br />Stage 1. 25Nm<br />stage 2. + 60 degrees<br />stage 3. +60 degrees<br />stage 4. + 60 degrees<br />Sequence as above.
Jan 09, 2013 | Opel Corsa Cars & Trucks
cylinder head torque settings for 1995 hyundai accent 1.5
Feb 14, 2011 | Hyundai Motor 1995 Accent
4,316 people viewed this tip
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
