Tip & How-To about Miele WT945 Front Load Washer / Dryer
Miele WT945 Dryer Problems - Stage 2 fix
STAGE 2: EASY ROOT CAUSE FIX (1 hour)
The next stage is to attempt a cleanout of the fan box itself. Fortunately you can get to some of what is needed without dismounting the whole box (if you want to bite the bullet on this straight away, go to Stage 3).
Dismount the heater by undoing the two large bolts at the front holding it to the drum, and two Torx bolts at the rear. Although the heater is still attached to the flexible rubber outlet at the front, it will swing up and off to one side just enough to reveal an upward-facing hole at the rear – this is the air outlet from the fan box. Peer down into this hole and you will be astonished at the buildup of mummified fluff and goo – it’s similar to papier mache.
Draw up a comfortable chair, fix up a desk lamp to shine down the hole, and start unpicking the goo with a fine metal hook (a dentist-style hooked probe is ideal – Maplin do a good set). First clean out the hole, then probe deeper to clean out each fan blade. It’s fiddly and quite a long reach down the hole, but by no means impossible. Turn the motor manually to move on to the next blade, and every so often vacuum out the hole with a small nozzle to remove the pile of dislodged goo. Unfortunately the goo is too adherent to come out with the vacuum alone, without unpicking first.
Finally, if you are confident with moving parts and mains electricity, you could finish by using the first few seconds of a dryer cycle to get the fan itself to blow the remaining dislodged goo out of the hole. Have the vacuum going while you do this to avoid a fountain of fluff! Also, be very careful that the heater and its wiring does not obstruct the motor while you are doing this.
With luck this will make a huge difference to the dryer’s performance, not only eliminating the motor seizures but generally restoring the airflow power considerably.
If you’re still having problems, or if you have an uneasy feeling about all the goo you still suspect is in there that you couldn’t see or reach from the hole, read my next tip 'Stage 3/4 fix'.
Miele WT945 Front Load Washer / Dryer Logo
2000 Volvo V70 climate control problem - blower remains in high, regardless of AUT 0-High setting. Vent selection and temperature controls work. Any idea?
Most common cause of this problem is a bad climate control power stage. The power stage control the speed of the blower fan on different settings, if it goes bad it defaults to full blast. There is a small chance the climate contro lunit itself is bad but more than 90% of the time, it is the power stage. It is located near the blower fan under the dash in the passenger footwell area. It makes it much easier to remove the glove box and knee bolster as well as the cover panel. It is rectangular in shape about 1.5" x 3" and black.
Nov 01, 2009 | 1999 Volvo V70
Miele WT945 Dryer Problems - Stage 3/4 fix
An excellent instruction set. I've been doing this lot for 4 years now. It is all down to poor intial design of the fan itself whose fins are far too close together and so clog up easily. I am left with the distinct impression that this was a deliberate ploy in order to sell lots of replacement fan boxes at £385 a shot plus VAT plus the call-out. Unfortunately, now the water pump is no longer coming into play during the dry cycle. Any ideas anyone?
Feb 21, 2010 | Miele WT945 Front Load Washer / Dryer
My tall Cinni standard fan isn't working. When you switch it on you can hear the motor trying, but the fan blades don't move at all. It's boiling today in my office, so we'd like to know what might be up so we can fix it asap.
Stage 1: unscrew 2No. top and bottom nut/bolt put to one side, lift 4No. hinge clips and remove front cage.
Stage 2: partially unscrew spindle screw on fan body then slide fan off spindle.
Stage 3: plug in fan turn to setting '1' (lowest setting, the motor will hum but not rotate) now with a hammer 'carefully' tap the spindle so that it is aligned within the housing, it may need to lo left, right, up, down whatever direction it needs to sit centrally withing the bushes of the front and rear housings. Then tap the end of the spindle which sometimes re-engages/realigns the spindle within the rear bush.
Stage 4: reverse of stage 2 & 1
Good luck
Jul 01, 2008 | Heating & Cooling
4,318 people viewed this tip
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
