Tip & How-To about Computers & Internet
How to fix computer freeze
Your computer may freezing and shut download randomly.
A corrupt registry is the most common cause! Registry is an important part of the windows operating system . This component of Windows system restore all of the computer information. It connect programs to your computer, with this component Software and hardware can run smoothly.
Cleanning registry always the most easy way.
Download RegTool and do a registry scan now!
Computers & Internet Logo
my laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help because my laptop is very much needed
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 02, 2010 | Acer Aspire 5315 Notebook
my laptop will randomly freeze every 20-30 mins, i have no viruses i have wise registry booster and wise registry disk cleaner, it was working perfectly then the next morning i turn it on it starts freezing, i have downloaded all software updates , i have done everything , please help.
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Oct 17, 2010 | Toshiba Satellite A135-S2276 Notebook
why you tube ?s not opn?ng
Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reg in out and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Oct 14, 2010 | YouTube Videos
acer one 751h freezes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
computer restarting Click Start and Open the Control Panel 2. Go to System and Maintenance, Click on System. 3. Select Advanced System Settings and choose Advance tab. 4. Under Startup and Recovery, click on Settings. 5. Under System failure uncheck Automatically restart. Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers bios during boot (usually by pressing Delete, F1 or F10 when the computer just starts) and there will be an option about the computers temperature (often under "PC Health"). U can have registry error.Run a registry cleaner reg in out .
Sep 21, 2010 | Acer Aspire One PC Notebook
Freezes after few minutes
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
207 people viewed this tip
David Payne
David Payne
