Tip & How-To about Office Equipment & Supplies
How to speed up your PC? PC slow is caused by problems in the registry that accrue over time. Installing and uninstalling programs leave behind fragments ? stray files, orphaned startup tasks, corrupted drivers. Over time the registry starts to get bogged down and conflicts emerge. Left unchecked, your system will become increasingly unstable, run more slowly and crash more frequently. The Solution RegTool is the easy answer to registry problems. It conducts deep scans of your registry to check for errors and conflicts, then repairs and optimizes the registry to peak performance and stability. Periodic scans will keep your registry "clean" and will greatly enhance your system's performance and stability. You'll see immediate increases in speed and decreases in system conflicts. Do a free scan and speepup your PC now!
why is my OS is very very slow working???
Here's a few tips you can try to fix your slow startup problem. First of all you want to disable any programs that are in the startup menu that you do not absolutely need. There is no sense in waiting for programs to load that you don't use on a regular basis. Or if you are not sure which one is slowing your startup. You can disable them one at a time.
If that did not help, you can disable your Windows sidebar. You'll also want to remove any icons from your desktop that you do not absolutely need. The same goes for your task bar and quick start menu. All of these will slow down your boot time.
Check to make sure your anti virus program is not scanning at startup. Some programs are set to scan. When windows boots, by default. You will also want to do a full anti virus scan to make sure you don't have a worm or any other type of virus that is working in the background slowing your operations down.
The biggest reason for a slow boot time is a corrupt or damaged Registry. The registry will become corrupted from installing and uninstalling programs. Perhaps you have loaded programs onto your new Vista computer and were not compatible and then uninstall them. They leave behind files, which Windows tries to reference on startup. Since they are no longer on your computer. Your system goes through a long search trying to find them. You need to clean and optimize your Windows registry to eliminate any bad or orphaned files.
You can do this manually if you are an experienced computer technician. It is not recommended for most users. Windows does not have a built-in tool for repairing, cleaning, or optimizing your registry. You will need to download and run a third-party registry repair program to do this.
A good piece of software that will do this for you with a click of the mouse is a wise investment for any computer. You will have it for years to come, and can schedule it to do weekly maintenance. This will keep your PC fully optimize and running fast. It's like giving your computer a tuneup.
Jun 17, 2011 | Microsoft Windows Vista Ultimate Edition
i failed to get the chat window
This may be because of slow internet connection.
May 31, 2011 | Facebook Social Network
slow computer, seems to hang alot. how do I speed it up. done all the usual things.
the problem is u have a lot stored on the pc memory and when this are much it slow down your computer so what u need to do is check your desktop and delet some things u no longer needs or dont open too much pages on your home page this can make your pc slow down ok,thnks .
Jul 10, 2010 | Compaq Presario Notebook
Youtube Buffering is so slow
There could be a wide variety of reasons for slow buffering times.
1) Your area could have alot of people on youtube at the same time, causing the local servers to be overloaded.
2) You could have slow internet capabilities with your current internet service provider.
3) You may be using an out-dated web browser, or have too many plug-ins installed.
4) You may not have sufficient ram on your computer.
I would recommend using a browser such as the latest version of google chrome for fast speeds watching flash, and you could try certain software to speed up your video watching speeds, such as http://www.videoaccelerator.com/. And you may want to check out that your internet service provider is giving you good download speeds.
I hope that helps!
Mar 11, 2010 | YouTube Computers & Internet
lexmark Z600 series
Often this problem is caused by problems in the registry that accrue over time. Installing and uninstalling programs leave behind fragments — stray files, orphaned startup tasks, corrupted drivers. Over time the registry starts to get bogged down and conflicts emerge. Left unchecked, your system will somehow become more unstable, nothing to do with your driver at this time, i suggest you download a free registry scanner on the web and run all throughout your programs and file to repair any registry errors and alike, then you can run the installation once again. this is the first step in securing your system first, then later on install the driver. dont forget to mark this solution pls. goodluck
Jul 29, 2008 | Lexmark JetPrinter Z605 Color InkJet...
1,248 people viewed this tip
jasbo
jasbo
