Tip & How-To about Kodak Easyshare C190 12MP Digital Camera with 5x Optical Zoom and 2.7-inch LCD
How to set a Kodak C190 to save to memory card
After you have installed your memory card, you will want to press the "Menu" button. Now look for the set-up menu, scroll down until you see the "Image Storage" operation. Once you press the "Image Storage", choose "Auto". this will allow the camera to save to the memory card.
Kodak Easyshare C190 12MP Digital Camera with 5x Optical Zoom and 2.7-inch LCD  Logo
I have pics stuck in my internal memory and don't have a way to connect camera to computer---how do I get them on my memory card from the internal memory? I have Kodak Easyshare C875.
  • Set the camera's picture storage location to internal memory, if it's not already so set by pressing the Menu button and scrolling down to "Image Storage."
  • Press the Review button, then press the Menu button.
  • Use up/down to select Copy>>
  • Highlight an option and press OK.
To use your card from now on, make sure to set the picture storage location to Auto.
Sep 08, 2010 | Cameras
how can i transfer pictures from my internal memory to my memory card?
Make sure a card is installed in the camera. Set the camera's storage location to internal memory. (To change the storage location, press the Menu button then scroll down to "Image Storage.") Press the Review button, then the Menu button. Use up/down to highlight "Copy" then press OK. Use up/down to highlight an option then press OK.
Aug 17, 2010 | Kodak EasyShare C763 Digital Camera
Kodak easyshare Cl90 camera How do I format the memory card?
Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place). Turn on the camera. Press the Menu button, then go to the Setup Menu. Scroll up or down to the Format option, then press the OK button. Follow the prompts to format the memory card.
Apr 28, 2010 | Kodak Easyshare C190 12MP Digital Camera...
My kodak C190 camera is saving to internal memory, why is it not saving to the memory card? How do I fix it?
Press the "menu" button. Then look for the set-up menu. Once there scroll down until you see "Image Storage". Once on Image Storage choose "Auto", this will allow you to save to the memory card. Hope this helps
Feb 21, 2010 | Kodak Easyshare C190 12MP Digital Camera...
internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
1,413 people viewed this tip
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
