Tip & How-To about Computers & Internet
WAYS TO KEEP YOUR LAPTOPS AND PCS UP AND RUNNIG
1. Old laptops and pcs
Hardware starts having problems after about 2 to 3 years, increases significantly. To repair a fault in your laptops and pcs can cost you more than a new system. Therefore, consider replace your laptops and pcs every 3 years-it may save you more in the long run.
2. Power problems
Low voltages or power drops can cause damage to sensitive components in your laptops and pcs and even reduce their lifespan. This type of damage may be very fatal to your laptops and pcs , you can prevent this is by using a voltage regulator (stabilizer) which will protector your laptops and pcs
3. Pirated software
Using Pirated software programs will cause damage to your systems always buy original sofwares
4. Firewall and security
The Internet is full of hackers who are trying to steal files or customer records and delete important data. For this very reason, it’s important that your computer is updated with the latest security patches, including proper installation and maintenance of firewalls.
5. Back up s
Losing data can be truly devastating. In spite of this, many laptops and pcs owners fail to back up their data 100% of the time. In some cases, lost data can put a owners in to lots of problems, it’s still frighteningly expensive to retrieve it.
6. Spam, viruses, and spy ware
Good virus protection, Spam filters, and anti-spy ware programs as needed if you want a trouble-free computer. Most service calls are from people with problems directly related to these issues. Maintain your laptops and pcs weekly, to prevent wasting of you money
Computers & Internet Logo
Neither the freezer or the refrigerator side will stay cold. It is 11 years old.
11 years old ... will not cool ... will cost about $100.00 to have it looked at and if it is a compressor, that will be another $250 or more. Efficiencies have increased significantly in the past 11 years. Might make sense to replace it. Check with your utility,they may offer a buy back plan if you upgrade your frig.
On the other hand, you could have it repaired. It could last a long time yet ... but it will be a costly repair in my guess.
May 31, 2011 | Kenmore Side by Side Refrigerator
LCD flickering at the bottom of screen
This appears to be a faulty CCFL lamp which supplies the back-light.
Because it is less than 6 months old, I suggest you get it fixed under warranty.
If you try to fix it yourself you will void your warranty.
Feb 12, 2010 | Toshiba Satellite M305-S4826 Laptop
Greyish marks on Samsung 32'' LCD TV
it should be covered, can call 1-800-samsung for nearest authorized service center or go to samsung.com
Dec 31, 2009 | Televison & Video
Gateway 6438 System Slow down
use RAMBooster 1.6 . will solve your problem. use registry mechanic to repair the registry errors.
Oct 29, 2008 | Gateway MX6438 Notebook
port switch problem
Binz, have you tried doing a hard reset on the router, hold the reset button 30 seconds, login in will be user: admin password:admin -- if its an older model user blank password:admin, if that doesnt work, try updating your firmware, you didnt specify your router model, or I would link you to a firmware update
Aug 28, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
137 people viewed this tip
David Payne
David Payne
