Tip & How-To about Drills
How to jumpstart ni-cad batteries
If you use cordless powertools(especially De-walt)you may find that the nicad batteries die if not charged correctly.
You can "jumpstart" these pretty similar to the way you might jumpstart a car. What seems to happen is that the cells became furred with ions and one way to get rid of these is to spark them out.
There is a link to a website that i will post once i find the paperwork again.
Drills Logo
hi, i have a 18v rechargeable hand held vac (pirana brand). It wont hold charge or wont even charge. What can i do to revive and/or where can i get a replacement battery? Thanks
Before I gave up completly on this battery I would remove it from tool and put battery in freezer overnight. Remove from freezer and let set at room temperature for several hours. Try to charge and see what happens. I don't pretend to know why this works but I have done this with every thing from ceel phone batteries to cordless drills and several other tools. If you need a new battery you should be able to get one at any hardware store that carries De Walt tools. I know arond here True Value is one that carries a large selection of De Walt tools and supplies. Hope this helps. Thanks
Nov 16, 2010 | Dewalt Accessories Batteries 18 Volt
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
1,610 people viewed this tip
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
