By
jsrock516
Rank: Guru
Rating: 96%, 6674 votes
posted on Feb 28, 2008
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Comment by jsrock516, posted on Mar 29, 2008
Thanks for the input dustyrepair. I value any feedback I can get as I try to offer accurate and informative solutions. I too have worked on this appliance and, after noting this same problem frequently in the field, I was provided the advise by our "technical experts". I do not wish to name them, but you may be shocked to find out where the information came from. It was their theory that the 5 minute interval you mentioned was not nearly enough time in some circumstances for the control board to sense the rise in temperature from the heater circuit. It was also their theory that running hot water into your dishwasher prior to starting the wash cycle not only would reduce the time interval (because the water was already warmer than the cold water that normally sits in the supply line), it was also reduce the need for the heater circuits to on to heat the water. This would not only get rid of the potential error problem, but would also cut down on electrical use. After clearing the problem by using the steps I mentioned, and informing customers of what could potentially be causing the problem, I never had to go back on a service call. Coincidence? Maybe. I was also informed that later models had an upgraded control board that eliminated this problem. I'm not trying to dispute you, just giving you reasons why I came to this conclusion.
Was this helpful?106 people thought this was helpful
Comment #1
posted on Oct 31, 2009
By
drsooo1
Rank: Apprentice
Rating: 0%, 0 votes
Thank you very much. Saved me a lot of aggravation. Hate it when appliances start to fail. They all seem to follow in line. One after another.
Comment #2
posted on Oct 27, 2009
By
tthldavis2
Rank: Apprentice
Rating: 0%, 0 votes
For 3 weeks we've been without a dishwasher because of this. My husband went to a repair shop where the guy talked him into buying 2 parts ($56 worth), and said those HAD to be the problem. Getting someone to even come here to look was going to cost $180. So we thought buying a new one was the best option. Got your reply so quickly, and "fixed" it before my husband got home. He was so surprised, and we were both thrilled that we didn't have to get a new one, especially since this one is only 2 1/2 yrs old! Thank you so much for your quick reply and RIGHT ON advice! You rock!
Comment #3
posted on Oct 16, 2009
By
Corny
Rank: Apprentice
Rating: 0%, 0 votes
I was beginning to loose my temper over this. First, as a retired firefighter in California, I thought of all of the times I had told people to turn their gas off in the event of an earthquake. So I thought was a good idea that would be in a house that was vacant. That was until the gas company found the valve off and put a lock over it and closed my account (paid up automatically every month). My next step was to just close the valves to the water heater and stove. A few weeks later I thought it would be a good idea to run all of the appliances to keep the seals from drying out. No luck when I tried to start the fairly new dishwasher (just past warranty as the house has been vacant for several months). Also found that the dry time had frozen the food waste disposal and turning it with a broom handle was not effective. I am so happy to find this possible solution and will give it a try AFTER LIGHTING THE WATER HEATER! A VERY BIG BIG THANKS TO YOU
Comment #4
posted on Oct 13, 2009
By
cdrydenvt
Rank: Apprentice
Rating: 0%, 0 votes
THANK YOU THANK YOU I had that problem before and had sears come and fix it I kept the formula on how to fix it but some how the paper got thrown away. My husband said try the internet and I thought for sure it would take forever to find it again but 3 min. and I had my answer. It's working fine again.
Comment #5
posted on Oct 11, 2009
Thank you very much i spent an hour trying to get the dishwasher out and an hour just looking at it jiggling hoses and wires and just looking like i new what i was doing then an hour hooking it back up just to have that light continue to flash. my wife is exstatic when i pressed those buttons and whammmmmmmm it works. thank you so much
Comment #6
posted on Oct 06, 2009
Thank God for smart people and information on the internet!!! We just moved into a new place and we have been using the normal cycle with no problems. Earlier tonight we used the pots & pans cycle and after we unloaded and reloaded with the second load of dishes the "clean light" just flashed and wouldn't let us run a second load. I tried unplugging and slamming....nothing worked.....Thank you for your wonderful wisdom!!! I reset using the Normal wash and heated dry and it started working again. We will be using only the normal wash from now on. You rock!!! Thank you Thank you Thank you!
PS-in our last home we bought a great BOSCH!! Never had any issues and cleaned like a charm!!! Whirlpool sucks.
Comment #7
posted on Sep 20, 2009
Well, my goodness, I haven't tried your recommended "fix" yet, (we pulled out the dishwasher, Kenmore, 4 yrs. old) and were ready to haul it to the dump; tomorrow we will reinstall it and see if your "fix" works. I'll let you know tomorrow. THANK YOU for having this info available.
Blessings
Comment #8
posted on Sep 18, 2009
By
ByronCO
Rank: Apprentice
Rating: 0%, 0 votes
Thank you very much. My Elite took five cycles of the button sequence to enter the diagnostic mode. It is pretty pathetic that Sears does not have this in the troubleshooting section of the manual.
My blinking light was telling me the truth - no water going into the dishwasher. A hose slid off, as the clamp around the hose was not tight enough (thanks Sears install guy), and water was all over my kitchen and basement. Anyway, simple fix with a new clamp, but the lights needed a reset. I tried unplugging the dw but no luck. Then google. Viola. Problem solved and dishes are being washed as I type. Thanks again.
Comment #9
posted on Sep 15, 2009
By
blond_inva
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the advice, it worked! For a few days I tried to cancel the blinking clean light and couldn't do it. It would blink 8 times, pause, and then the sequence would repeat. I felt like I was in an episode of "lost". I followed the directions and pushed the buttons in the sequence of normal wash, heated dry, normal wash, heated dry, normal wash, and it went into the diagnostic mode where all the lights lit up. I hit cancel and I got a countdown display of two minutes remaining. After the countdown, all lights went blank, and I hit start. It started right up! Yea!
Comment #10
posted on Sep 13, 2009
By
Hawkestone
Rank: Apprentice
Rating: 0%, 0 votes
Thank you, thank you!!! A repair service that came to fix my 4 year old Kenmore model 17032 told me that I needed a new heating element and water pump to solve the blinking clean light problem but that it wasn't worth fixing and I should replace it. Sears Repair Service's only suggestion was to send one of their technicians out, which meant paying for another diagnostic call (I wonder why they couldn't have suggested I try the solution posted here) and Sears Customer Service kept me on hold for over an hour before I gave up trying to speak with them. After 3 months of hand washing dishes, while browsing for new dishwashers I found your website and the solution worked immediately. What a great service your website provides.
Comment #11
posted on Sep 10, 2009
By
jwadethack
Rank: Apprentice
Rating: 0%, 0 votes
thanks jsrock.. you rock!
Comment #12
posted on Aug 29, 2009
By
lsnggls
Rank: Apprentice
Rating: 0%, 0 votes
THANK YOU SO MUCH!!!! I have been trying to get Sears to come and service but this worked!!! I cannot thank you enough~~~ YOU GUYS ARE AWESOME!!!
Comment #13
posted on Aug 02, 2009
You are awesome, thank you so much. I knew it had to do with a sensor but i am not electronically enclined, so i was at a loss. your advice did the trick and we will now run the hot water before doing a load. thank you again, have a good one
*Dave*
Comment #14
posted on Jul 21, 2009
7-21-09 Thank you so much!!! My two kids are jumping for joy now that the dishwasher is working, because they had now become the dishwasher. Your advice to press the two buttons on the control panel worked exactly like you said it would. Kudos to you :)
Comment #15
posted on Jul 15, 2009
By
barkbanks
Rank: Apprentice
Rating: 0%, 0 votes
Been trying to figure out how to fix "my" blinking green clean light on my Kenmore Smart wash dishwasher. I don't have a Heated Dry Button.
Continued reading on comment section, only to stumble upon the suggestion to use Sani-Rinse/Air Dry as the magic combination to get my dishwasher in Diagnostic Mode. Had both those bottons. Tried it, AND IT WORKED!!! Thanks so much!
Comment #16
posted on Jul 14, 2009
Okay, so I did this. I reset it and I started to run the dishwasher. But, after a few minutes, it stopped the washing cycle and went straight to the end with a blinking clean light again.
What should I try now? I did go ahead and ran a diagnostic cycle. I thought that it would give me a code or something at the end, but I got nothing.
Any help would be great.
Comment #17
posted on May 01, 2009
By
fracmaster
Rank: Apprentice
Rating: 0%, 0 votes
Well glad to see we were not the only ones with this problem. Our 12 yr old daughter thought she had done something to the dishwasher and had to wash dishes by hand! She hated every minute of it and now she knows what life is like without a dishwasher...
Comment #18
posted on Apr 12, 2009
By
ummbnb
Rank: Apprentice
Rating: 0%, 0 votes
I found this a couple of weeks ago the first time we had the mysterious blinking light issue. It fixes the problem for that round but it continues to happen every two to three times we run the dishwasher. Any thoughts?
Comment #19
posted on Apr 04, 2009
OMG ! IT WORKED! THANK YOU !
i just had a major appliance break and the dishwasher was the dbl whammy !
i am sooooo grateful
the dishwasher whirlpool quiet partner III works great its running right now!
----saved from $$$ service call
Comment #20
posted on Feb 08, 2009
By
tktravas
Rank: Apprentice
Rating: 0%, 0 votes
I have a KitchenAid dishwasher that was having the same problem. The button sequence posted by Master_123(Comment #15) worked like a charm.
Comment #21
posted on Jan 31, 2009
By
crsamuels
Rank: Apprentice
Rating: 0%, 0 votes
Thank you sooo much for your information! It worked like a charm! I had already made an appointment for Sears to come out to fix this problem. You'de think that they could have told me the simple solution that you did! You saved me at least $75! Thanks again!
Comment #22
posted on Jan 30, 2009
By
kellyeckel
Rank: Apprentice
Rating: 0%, 0 votes
You're the man JS Rock!
Comment #23
posted on Jan 19, 2009
By
TRJsmom
Rank: Apprentice
Rating: 0%, 0 votes
Thank you sooo much. Your tip worked perfectly and saved us from having to pay for a service fee (of course our warrenty ended last month). In these hard economic times, it is good to know that there is someone who is trying to help people save a little money. Thank you Jsrock516!!
Comment #24
posted on Jan 13, 2009
I Had a blinking " clean light ' on my Quite Guard 7 , I used the sequence and it worked great.
Thanks for saving me some money in these hard times.
Comment #25
posted on Jan 05, 2009
By
kmoff1965
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the tip jsrock516, I had turned the washer off at the breaker box trying to reset it and several other things and that was the ticket. Apprec, that saved me a repair call bill.
Comment #26
posted on Dec 29, 2008
By
camcheney
Rank: Apprentice
Rating: 81%, 4 votes
thank you, I was trying to figure out a way to return this piece of junk. I'm grateful for your expertise. Cam
Comment #27
posted on Dec 25, 2008
I have a Whirlpool Quiet Parter I - I think the model # is 3385818. I tried this sequence and all the green lights lit up. I hit cancel and then started a normal wash and it running perfectly! Thank you for the tip!
Comment #28
posted on Dec 23, 2008
By
jnelzinwyo
Rank: Apprentice
Rating: 0%, 0 votes
This also worked for my Frigidaire dishwasher. You just saved me over $100!! Thank you!!!
Comment #29
posted on Dec 19, 2008
By
benzhai
Rank: Apprentice
Rating: 0%, 0 votes
I had blinking "clean light" on my Whirlpool KUDUO3FTSS1 for the whole last week. After trying Jsrock516's trick by pressing Normal Wash then Heated Dry buttons three times, all lights come on, I shut the washmachine door, then press the start button, the wash machine starts to wash itself and the clean light is not blinking anymore. Thank you for the tips, save my phone call to Whirlpool. Appreciate!
Comment #30
posted on Nov 06, 2008
I have a KitchenAid KUDP02FR. Must be the same manufacturer because it has the same problem of the cleaning light blinking seven times. Based on the comments here I tried pressing Sani-Rinse, Heat Dry, Sani-Rinse, Heat Dry until all the lights come on (twice mostly). Then I closed the door and it ran and clicked for about 5 minutes then stopped. After that it runs like normal again. THANKS.
Comment #31
posted on Sep 10, 2008
By
dmr21
Rank: Apprentice
Rating: 0%, 0 votes
FYI - for the Whirlpool GU1500 the button presses to enter diagnostics are-Sani Rinse, Air Dry, Sani Rinse, Air Dry, repeat a couple of times.
Press w/ door open
Repeat until you see everything light up,close the door and let it run through the self diagnostics. After that, select a cycle and try it (as I'm doing right now).
Was previously locked up after a control board replacement and had the clean light blinking 7 on, pause etc. and no cycles would start. The unit ran a "quick wash" cycle after board replacement but the "clean" light never went out and hung up.
Will check that the "clean" light goes out after opening and closing the door as before and hope to post up success if I'm not in the middle of installing a Bosch DW.
Not a fan of Whirlpool, unit died just over 2 yrs and it took > 5 wks to get the warranty replacement board. They didn't want to send it without a "certified Whirlpool service technician" looking at it first @ $120 for a visit in my area. I talked to them and they told me how many problems they had with these boards and that they would feel bad taking my money since the board was 95% certain to be the problem.Whirlpool disagreed but eventually (2 managers later) agreed to send me the board. No mention of the diagnostics mode even though I asked about that first and several times.
The board was supposedly shipped on 8/4/08 but after 3 calls, they had to re-send and I got mine on 9/5. People were nice but clueless.
Wish me luck geting this done or Bosch it is.
Comment by dmr21, posted on Sep 10, 2008
Well, it ran half a cycle and then stopped. Will try again but I've already spent a ton of time on the phone w/ Whirlpool and they offered zero technical assistance. Everything I've tried has come from the web.
Probably buying a Bosch tomorrow.
Comment #32
posted on Sep 03, 2008
By
Colleen3
Rank: Apprentice
Rating: 0%, 0 votes
Looked and looked for my owner’s manual, couldn’t find it. I spent 24 hours with that green clean light blinking at me. I love the internet and I love you jsrock516!
Comment #33
posted on Aug 25, 2008
By
slavpro
Rank: Apprentice
Rating: 0%, 0 votes
You guys are on top of it, the code cleared. Lets hope it stays clear. Thanks again, you guys rock
Comment #34
posted on Aug 17, 2008
By
drew70
Rank: Apprentice
Rating: 0%, 0 votes
It worked perfectly for me!
I bought my Kenmore Ultra Wash Quiet 3 dishwasher brand new. Used it a couple of times and then it "broke." I kept putting off calling in a repairman because I'm somewhat of a cheapskate and besides, I don't generate a lot of dirty dishes. For the last two years I've been washing dishes by hand. I only happened to stumble onto this site while looking for a manual.
I saw this post and thought, could it actually be THAT simple? It was!
Thanks a million!
Comment #35
posted on Aug 15, 2008
By
Master_123
Rank: Apprentice
Rating: 85%, 3 votes
The blinking light problem ( clean light blinks 7 times) if the thermistor fails to detect 2-4 degree F raise in waster temperature during the wash cycle.This will make the Timer produce a fault.The main problem in most of the cases could be caused by Bad heater/thermostat/door switch/heater relay or unbalanced dishwasher that causes the door switch to open(one switch) while trying to heat the water.This problem could be also caused by a very low water level in the dishwasher or a bad water pump since the if there is not enough water in the machine or if the water pump is not pumping water through the spray arms, the water will not touch the heating element and therefore the control board will not detect 2-4 F increase in water temperature and then will produce a fault. A bad(shorted or open) thermistor can not be the cause of this problem since a the thermistor in these tow cases will produce an extreme water temperature ready and the control board will skip this temperature check.One more thing, if the Temperature is extremely cold or hot, the control board will bypass this temperature test.
Newer kenmore modules have different control borad desighn in which the control board will produce the blinking light if the thermistor fails to detect that increase THREE times.The way to clear the fault is ( Hi temp-->air dry ; Hi temp-->air dry -depending on the module)
I hope that was helpful,
SEARS Engineer
Comment #36
posted on Aug 06, 2008
By
canfieldt
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the tip - it worked great!
What a great site.
Comment #37
By
Pooka0004
Rank: Apprentice
Rating: 0%, 0 votes
Before I found your wonderful advice I bought a new recommended part $100 from the company and they told me if it did it again another part was needing to be replaced that would cost $100....Grr! So thank you SO VERY MUCH, you saved us money, time and wet hands! :-)
Comment #38
posted on Aug 05, 2008
By
davidjtoth
Rank: Apprentice
Rating: 0%, 0 votes
Great tip!!! After trying 3 function tests on my Maytag dishwasher MDB7160, calling Maytag technical support and going to the library all to no avail, I finally found this website.
Although, you only mentioned Kenmore and Whirlpool I gave your tip a try on my Maytag and it worked immediately!
Your suggestion makes sense because we were on vacation for ten days and had no one running the water in the house for us. My wife is happy once again.
Thanks "jsrock516"!
DJT
Comment #39
posted on Jul 31, 2008
By
nixie_pie
Rank: Apprentice
Rating: 0%, 0 votes
Thank you soo, much! My Husband was supposed to figure it out two days ago and he didn't. We also lost the user manual so we were kind of out of luck. I went online looking for a online user manual and found you. Now I fixed it all by my self! Thanks!
Comment #40
posted on Jul 26, 2008
By
Sbrown11
Rank: Apprentice
Rating: 0%, 0 votes
saved me time and money, worked like a charm. thank you.
Comment #41
posted on Jul 12, 2008
By
Carlisle
Rank: Apprentice
Rating: 0%, 0 votes
You are amazing. I can't thank you enough! Your tip worked like a champ and avoided having to call a repairman on a Saturday -- which gave me a tremendous sense of satisfaction. Thank you.
Comment #42
posted on Jun 08, 2008
this was the perfect answer for my dishwasher.i was going crazy,i have back problems and standing just doesnt cut it.did the normal wash then heated dry,it only took two times.it entered diagnostics,cleared the fault and works like a dream.a real life saver.thank you jsrock516
Comment #43
posted on Apr 03, 2008
By
tech 302
Rank: Apprentice
Rating: 0%, 0 votes
Great advice!!! worked like a champ. Keep in mind my problem was because of a new water heater-a tankless one , I will be installing a 5 gallon electric after the tankless to eliminate this and some other small issues.
Comment #44
posted on Mar 23, 2008
I have been repairing this dishwasher for the last 3 years. I have never seen water temp cause the blinking clean light. according to whirlpool that cannot and will not happen. In fact the control board will bypass water temp if coming in too cold or to hot. If after the first five minutes of the wash cycle if the control does dot sence a rise in water temp from the heater then and only then will the blinking clean light will start to flash
Comment #45
posted on Mar 18, 2008
By
kevin11
Rank: Apprentice
Rating: 0%, 0 votes
Great advice jsrock516. Worked like a charm.
Can you Help with these Dishwashers problems?
Kenmore 24 in. 17482 / 17484 / 17489...
I have a Kenmore Elite dishwasher and the under counter...
I have a Kenmore Elite Dishwasher that is 3 yrs old, which...
fo show on display panel oven will not work
soap is not dispensing
used dishwasher a couple of times then there was no power...
