Tip & How-To about Computers & Internet
How to troubleshoot laptop startup problems
When your laptop lights momentarily, but almost immediately shuts down, try removing the battery and booting the unit with the battery removed. If there are any problems with any devices such as the battery, fan, ram, wireless card, dvd or hard drive the unit will not boot. You should also remove the cd, ram, wireless card and the HDD. With those items removed if there are no other problems your unit will boot as far as the BIOS and then prompt with a message saying there is no operating system. This would eliminate the motherboard as the problem. If your unit does not boot to the prompt you have a fan problem or a motherboard problem. At this point you would have to remove the bottom cover and try to boot while watching the fan for movement. No movement, replace fan. Movement, replace motherboard. It it does boot to the prompt try reinstalling the HDD and booting. If it won't boot then the HDD is bad and would need replaced and formated with the original factory discs. If it boots with the HDD, try installing the ram and booting. Same procedure until you find the bad part. This will take some time but should narrow the problem to the bad part.
hardrocko
Thanks for using FixYa
Computers & Internet Logo
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
my E5430 laptop will not reboot - tries to and then shuts down
Can you boot into diagnostics without it shutting down? Try it while plugged in and the battery removed.
Jun 25, 2014 | Dell Latitude E5430
dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
i shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Toshiba 5205-S503 Laptop- No power
- You may want to try to reseating all neccessary things on the system like optical drive,hdd,memory but before you do that disengage the power from the system like the ac and battery.
-If no..go try to remove the optical drive first and then turn the system on, then if the system boot without the optical drive shut it down and put back the optical drive and boot to bios and load the default setting and boot the system normally.
Oct 11, 2008 | Toshiba Satellite 5205-S503 Notebook
4,514 people viewed this tip
David Payne
David Payne
