Tip & How-To about Computers & Internet
Get a faster start of your PC on Windows OS
The main reason of ur PC started a little harder than u would expect is that too many programs run at the startup. In most of the times many of these programs are not so important and could be run at a further time.
So what you need to do:
Click Start Button than click Run. Type msconfig and click the StartUp Tab . I think it's the 6th top tab . (that is in Windows XP Os). From there u can select or deselect what u consider that is usefull or else.
Computers & Internet Logo
My Acer Aspire 5742 runs so slow even after a reboot, what can I do? Thanks. Kevin.
Hi Kevin...you can install a free software like cc cleaner and run to remove cookies and temp files on ur PC
->perform a defrag of the Hard disk
->you can increase virtual memory
->you can disable some unwanted programs at startup
->can do a registry cleanup if it works well and good if not
my email address is jalander.reddy@gmail.com please email me when ur free and ur convenient time so that i can take and work on ur PC and try to optimize ur PC performance..n it wud be for free.
Oct 01, 2013 | Acer Aspire One AOA150-1784 Netbook
This file runs every time the computer is turned on and slows it down. Is there a way to remove it? I did remove it one time but can't remember what I did.
You need to specify what "file" runs every time the computer restarts.
Assuming you have Windows XP, you should check first in your "Startup" folder (Go to START -> PROGRAMS -> STARTUP). The "file" that runs every time the computer is turned on should be there. If it's not, please report back fro further assistance.
Apr 01, 2010 | Dell Inspiron 8600 Notebook
my laptop keeps freezeing
do you have any expired version of antivirus products like Norton, Mcafee etc. If you do, uninstall them and restart PC.
Notice the results.Awaiting response.
Hope it helps !
Thanks
Sep 09, 2009 | MSI GT735-024US Notebook
It takes too long to start up
Try deleting your temp files to clear up space as well as run hard drive defragment and disk clean up. This helps most time. If you find that your systems is still running slow, you may need to add more memory to process the data you have on your hard drive.
Good Luck
C2Solutions
Aug 07, 2009 | Dell Inspiron 530s Desktop Computer...
speed
Actually there are many reasons why your computer will boot up slow. I can only give you some tips.
Click start>run>type msconfig. On the startup tab uncheck any program that you don't need on startup.
Delete Prefetch files. Prefetch files are being created by windows when you open a program so thaht the next time you open the program it will pull up faster. But having too much prefetch helps slow your computer down on startup because it loads on startup. to delete go to start>run> type prefetch. delete all that you will see there.
For trojan problems the best way to remove them is by running a scan of updated antivurus program. If you don't have one. try SuperAntispyware. it worked for me. =)
Oct 09, 2008 | Microsoft Office Professional 2007 Full...
118 people viewed this tip
David Payne
David Payne
