Tip & How-To about Computers & Internet
How to install device drivers using driver files without a setup
Obtaining drivers is a very important aspect in the everyday use of a PC since outdated drivers need to be updated. Drivers can be downloaded from many different sources on the internet and through many third party software programs. Whatever the source, there are a number of times that people download drivers and they realize that what they have obtained are just the raw driver files without any setup. A lot of people get stranded in such cases. The following, is a very simple way of installing these driver files:
Whether under Windows XP, Windows Vista or even Windows 7, do this:
1. Click on the start button and right-click 'My Computer' or 'Computer'.
2. Select manage and wait for the resulting window (if asked whether to continue, continue).
3. Select 'Device Manager' from the left panel.
4. Now, depending on the device you want to install the driver for, or update its driver, right-click the device (you may have to click on the plus sign to reveal hidden devices). select the first option (update driver software) from the drop-down options.
5. In the case of Windows Vista and Windows 7, select browse my computer for driver software and then browse for the folder that contains the files.
6. In the case of Windows XP, select the last option which avoids the internet and click next and select manually locate files and next. Now add the location of the folder that contains the driver files.
7. Click next and Windows will automatically install the driver files for your device.
8. Restart your PC and you are done.
This procedure is not necessary when a setup file is available unless the setup file is corrupted but the driver files are available.
Hope this was helpful and all the best.
Computers & Internet Logo
i need drivers for an advent dt2204 pc
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Jan 16, 2013 | Computers & Internet
No Sound
Every time Windows update runs, or a device or program is installed/uninstalled, there's a chance one or more of your sound drivers may become outdated or corrupt, resulting in "no sound". Note: Most manufacturers provide free driver downloads on their official website(s). However, these sites are confusing for even the most experienced technician, and there's a risk that the wrong drivers may be installed onto your system. Installing a wrong or outdated driver can crash your computer. go to driverboost.com to download.hope it helps.
In just 2 minutes, DriverBoost locates the exact, most up to date sound drivers for your system and connected devices. No guess work, no hassles, and more importantly, no risks of installing the wrong driver and harming your computer. With regular scans, DriverBoost will notify you of any and all device driver updates to ensure your computer runs at peak performance!
Run DriverBoost, to automatically update your sound drivers and fully restore PC sound in 2 minutes
May 07, 2011 | Computers & Internet
i need a awrdacpi audio driver
In order to assist you with your problem - Please get your PC ready.
With no Programs running except the Internet Browser.
Step 1 - Identify your Audio Card -
You can try search for Driver Updaters on the Internet
or Try to download on torrent sites.
like www.piratebay.org
and SEARCH = Driver Updater or Driver Genius
^note - in order to download TORRENTS u need torrent applications such
as www.utorrent.com :) DOWNLOAD and INSTALL
Step 2 - Install the Updater and Put in the serial.
Make sure your Internet is running good.
Do NOT UPDATE the program.
Step 3 - SCAN your PC for outdated hardware drivers
Step 4 - DOWNLOAD ALL and INSTALL
Step 5 - Reboot PC
Feb 17, 2011 | Intel Computers & Internet
video drivers
There is a program called Secunia PSI that is free for home use. You download it, scan your computer with it, and it shows everything outdated or end of life. It provides a button you click and it goes to the site, downloads and installs the drivers for you. It must be in the advanced mode to do this. Odds are there are other drivers you have that may be outdated.
Go to www.secunia.com and download the PSI program.
Sirwriter
Nov 02, 2009 | Computers & Internet
drivers are outdated
When you install certain software, they might show your drivers are outdated. That is because the manufacturer may have released newer versions. However if your computer is working fine, there is no need to update the drivers!
Apr 26, 2009 | Computers & Internet
491 people viewed this tip
David Payne
David Payne
