Tip & How-To about Computers & Internet
Remove BIOS Password on Toshiba Satelitte A135-S4637
If your system BIOS password was set and your forget it or if say another person or child set it you can reset the password with the steps below. This requires partially opening the case and shorting a part of the motherboard. If you are not comfortable doing this, get a technician to do it.
1) Remove Laptop Battery
2) Take off Memory Cover
3) Using two thumbs spread clips to outside and
pull out RAM memory. Repeat this if you have 2 modules.
4) Gently remove the vinyl cover on the motherboard. Be careful because it can rip.
5) Position the laptop so that the memory slots are facing away from you. Look for the silkscreen marking, "J1". Inside the square next to it looks like two E's one inside the other. Take a wire and short these Es out and place the other end of the wire on the case post located in the center top. Hold for about 15-20 seconds.
6) Put the vinyl cover back on.
7) Place back your RAM memory
8) Put the cover back on.
9) Put battery back in.
10) Turn the unit on, it should mention that the CMOS was reset. You should see a selection of F1
or F2 for setup. Using the F2 gets you into the Bios
menu where you reset the time and date. Then Tab over to
the Security setting tab and change your passwords. Now
hit F10 key to save the settings and your computer should reboot.
Your BIOS password should now be complete.
Computers & Internet Logo
how can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
dell inspiron 700m break the password
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-700m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 01, 2011 | Dell Inspiron 700M Notebook
my son forgot his password in his acer aspire netbook how do we reset his password? we tried the reset bar and that didn't work. help
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help your son too.
Nov 03, 2010 | Acer Aspire 5050-3242 Notebook
my acer aspire one crashed and i need help
Below are the steps for the resetting of the password. Below the steps is the link for the service manual. On page 113 is the picture of the jumper pads that need to be "shorted" to reset the cmos.
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
http://tim.id.au/laptops/acer/aspire%20one.pdf
Dec 26, 2009 | Acer Aspire One PC Notebook
reset bios to factory settings in dell optiplex gx520
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
Can click the link below to see how its done or follow the steps below :--
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=87&~cat=12
Choose the desktop model and continue.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Else can follow Optiplex User Guides.
Hope it helps !!
Thanks.
Sep 14, 2009 | Computers & Internet
770 people viewed this tip
David Payne
David Payne
