Tip & How-To about Saws
My Blue Laser
Ever wish you could make that perfect cut the first time with your miter saw or table saw ? Simple if you put a strip of wide blue tape on base of saw and cut the tape with your saw ! Now you know where the blade will cut, now mark your wood, move the wood and the pencil mark to edge of tape that you just cut and cut it. That simple and easy to calibrate verses the red lasers that come on some saws that to me never work right to begin with.
Valley2118
Saws Logo
blade is not square to table
There are manuals for the Skil 3400 available online.
Centering the blade to the table simply requires a screwdriver, a good square, and some patience. Basically you're loosening up the points that hold it vertically and horizontally (front to back), checking them against the table with your square, and then tightening them up when everything looks nice and ninety degrees.
It's not the best saw in the world, but with a little work, I've been able to get it to make 90 degree cuts and perfect miters with a miter sled and a cross-cut sled I built using aluminum (I think?) T-shaped replacement runners that would normally be used for the worthless miter guide that comes with it.
Apr 23, 2014 | Skil 10" Table Saw 3400
i have an outside corner cut with a 45 degree slant and cannot figure out what my angle should be to get the right outside miter cut
You can solve this with geometry, but it will take forever and your answer will only be approximate (due partly to the limits of accuracy of the scales on your saw). If you are using a table saw, use scraps of wood and trial and error. It takes a while, but you can get a perfect result. If you are using a miter saw, then support your work from underneath at the angle to match your situation, and simply cut at 45 degrees.
Aug 31, 2010 | Dewalt DW744S 10" Portable Table Saw with...
will not cut 45 miter cuts perfect
Possible but I would think not likely
Try this
Put a new blade on
Set a magnet on the table or fence with phillips screw driver stuck to it
Slide the point of the screw driver up to within 1/16" from the blade just above the teeth
Run the unplugged saw by hand and watch for any side to side movement of the blade
Can you move the blade up and down or side to side?
If everything seems normal the plug the saw in and run it again watching the screwdriver
Please be careful don't allow the screw driver to contact the blade at high speed you will create a bullet
Mar 10, 2010 | Porter Cable Cable 12" Compound Laser...
The table binds when I rotate it to change miter settings. When I cut miters(45 degree) I'm not getting straight cuts along the edge. The saw is on a plywood base mounted to a Dewalt miter saw stand. I just changed the blade and cleaned real well. I have owned the saw 5 years. Problems started 3 weeks ago, in the middle of a trim project. I'm building boxes and trimming out the 4x4 posts on my pergola.
Could be the wear plates under the table between it and the base. Or if it doesn't have any then the two mating surfaces are dry and rubbing causing this problem I would suggest going to Dewaltservicenet.com and typing in your model number and downloading a breakdown for the tool. To remove the table on most saws you have to remove the fence and that requires that you square everything up upon disassembly. Let me know and I will try and help further. By the way to clean the parts I use a surface conditioner with something like a scrubbing pad and then after everyting clean use a dry silicone lubricant or equivelant.
Sep 13, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Table and base not level (co-planar). Extension wings higfher than base as well.
Just read thru most of the user manual and they do not address this situation. Most major adjustments they list as Service Center meaning they might have to completely disassemble and find out hy this saw is not accurate, wish I had better news.
May 10, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
948 people viewed this tip
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
