Tip & How-To about Computers & Internet
How to Flash a System Bios using a diskette or a CD
Not all PC models have the option of flashing the bios under the windows Graphical User Interface (GUI) environment. There are some that their manufacturers only give diskette option which will involve using the DOS (Disk Operating System) environment. Recently, the CD drive is also given as an alternative since most PCs now do not have diskette drives. Well in both cases, it will involve creating a bootable diskette or CD. Here's how to go about it:
First, you would have to visit the manufacturer's website and carefully check and download the latest driver files for your system model. Also, you would have to save the instructions for reference when necessary. If you are downloading for a diskette, you would have to download the driver files for diskette (they are smaller than that of the CD). Now, the next thing is to create a bootable diskette so you can copy the downloaded files to the diskette. The easiest way of creating an MS-DOS bootable diskette is by visiting www.bootdisk.com/bootdisk.htm, download an image (you can select 'Windows ME, Custom, No Ramdrive'), and follow the instructions to create your own bootable diskette. If the bios files you downloaded are zipped, you would have to unzip first so you can have access to the actual files and copy them to the bootable diskette. If you are downloading for CD, then you would have to select the one for CD if available. Normally, with the CD, an application is added to automatically burn the bootable CD. You would have to be sure your CD drive is a burner or writer. Take note of your drive letter (whether E:, F:, A: etc). Now you are ready to lunch.
If you are using a laptop, be sure to have your battery and adapter connected and if it is a desktop, then be sure to have a backup power like a UPS. Restart your PC and be sure to set your PC to boot from Floppy or CD depending on which one you are using. Now the PC will boot into a DOS environment. If the main application does not lunch automatically, you would have to lunch it yourself. In this case, you will see a drive letter and a blinking cursor. If the letter showing is not that of your drive, then you would have to enter your drive. This is an example of what to type if say we want to enter drive 'E';
c:\>e: (then hit the enter key)
e:\>
In this case, we were in drive C: and we moved from C: to E: by typing 'e:'. From the instructions, you will know the main file to lunch. This is an example of lunching a file with the name 'bios.exe' in drive 'A';
a:\>bios.exe (then hit the enter key)
In this case, we were using drive 'A'(normally the case with diskette). If it were to be drive 'E', it would have been;
e:\>bios.exe (then hit the enter key)
When this is done, you follow the instructions step by step to successfully complete the procedure. When done, you can check your bios settings if necessary.
Hope this was helpful and all the best.
Computers & Internet Logo
What is a GUI installer?
It stands for Graphics User Interface(GUI), i.e. a windows installer.
Mar 17, 2015 | Dell Inspiron Computers & Internet
what is full shell command line
In computing, a shell is a user interface for access to an operating system's services. It can be accessed either via command-line interface (CLI) or graphical user interface (GUI). A command line shell is the one wherein you need to enter a command on a command-prompt window to access to your operating system's services.
GuruAid.com
Jun 25, 2014 | Gateway LX6810-01 PC Desktop
Just installed Ubuntu Server. I need a graphical user interface, and downloaded one but computer still boots to dos-like interface. I don't know Linux commands. How to get GUI?
1-If you are presented with the command line after Linux boots, And after you login and end up at the command line prompt, you Type:
STARTX
The above command start up the GUI from the command line, and Get you in the Graphic GUI environment of Linux.
2-If you Linux computer start up with the GUI, and you are Taken to the desktop environment, there is a way to access the Linux command line.
From your desktop, you can go trough the startup menu and choose the " TERMINAL", and this will let you access the Command line. You will end you with a windows with the Command prompt from within the desktop.
In summary, accessing the command line interface or the GUI Can both be done on your Linux computer, weather your system is Setup to start with the Shell interface or the GUI.
Nov 28, 2011 | Canonical Ltd. Ubuntu
what does gui means?
GUI is a Graphical User Interface, which is for making "Windowed" Applications.
Nov 01, 2010 | Microsoft Internet Explorer 8
What is the difference between unix and linux
UNIX is a operating system which has only command user interface, and if the unix is installed in the system you cant install any other operating system after that ... one separate system must be allocated for the unix ...
LINUX is the graphical user interface and it supports multiple operating system ..
UNIX and LINUX are almost same, almost all commands which supports in UNIX supports in LINUX too .. with some extended features just like GUI(GRAPHICAL USER INTERFACE),SECURITY,MULTI USER,MULTI TASKING,etc
COMMAND USER INTERFACE - the input is made to the computer by using commands and the output is obtained by command or by printer ...
GRAPHICAL USER INTERFACE- the input is provided to the computer through the other input devices like mouse,joystick etc
the input is provided either by command or by the just clicking the mouse on the particular icon ...
example for graphical user interface is windows,Macintosh etc ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Aug 19, 2008 | Microsoft Windows Server Standard 2003 for...
183 people viewed this tip
David Payne
David Payne
