Tip & How-To about Computers & Internet
INCREASE INTERNET SPEED BY 20%
1.Log in to ADMINISTRATOR
2. Start - run - type gpedit.msc
3. Expand the "Computer configuration" branch
4. Expand the "Administrative templates" branch
5. Expand the "Network" branch
6. Highlight the "QoS Packet Scheduler" in left window
7. In right window double click the "limit reservable bandwidth" setting
8. On setting tab check the "enabled" item
9. Where it says "Bandwidth limit %" change it to read 0-- Click apply, OK, exit gpedit.msc
10. Go to your Network connections (start->my computer->mynetwork connection-> view network connections). Right click on yourconnection, choose properties then under the General or the Networkingtab (where it lists your protocols) make sure QoS packet scheduler isenabled.
11. Reboot, and you’re done !
KINDLT RATE THIS TIP
Thanks And Regards
Computers & Internet Logo
slow buffering
- Log on as Administrator
- Start - run - type gpedit.msc
- Expand "local computer policy"
- Then expand "administrative templates"
- Then expand "network branch"
- Highlight the "QoS Packet Scheduler"
- On right window double click "limit reservable bandwidth"
- On setting tab check the "enabled"
- Change "Bandwidth limit %" to 0
- Restart PC
Hope so after performing these tips your Internet buffering speed will be increased. If Not! Then I would suggest you to download Reginout and use its feature Internet Optimizer.
Thanks
Nov 17, 2013 | zoosk.com
my net speed very down why can you help me
QoS Packet Scheduler is a method of network bandwidth management that can monitor the importance of data packets and depending upon the priority of the packet, give it higher or lower priority or bandwidth levels. It's not very useful unless you're using apps which are QoS-aware or running a server, so you can gain some network overhead back by turning it off.
Note: This following tip will not work on XP Home Edition.
  1. Make sure you're logged on as actually "Administrator". Do not log on with any account that just has administrator privileges.
  2. Start > Run > type gpedit.msc (not available in home version).
  3. Expand the Local Computer Policy branch.
  4. Expand the Administrative Templates branch.
  5. Expand the Network branch.
  6. Highlight the "QoS Packet Scheduler" in left window.
  7. In right window double click the "limit reservable bandwidth" setting.
  8. On setting tab check the ENABLED item.
  9. Where it says "Bandwidth limit %" change it to read 0 (ZERO).
  10. Close gpedit.msc.
Effect is immediate on some systems, some need to re-boot.
Jan 07, 2011 | Office Equipment & Supplies
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
taskmanager disabled by your administrator
Click on start then run
Type gpedit.msc then ok
Click + on administrative templates
Click + on system
Click on CTRL ALT DEL options
over to the right double click on remove task manager
Click on disabled then apply then ok
You will now have back taskmanager
This is normaly caused by malware you should if you havent already run an anti malware scan.
Malware Bytes is an excelent example of a scanner and is located here: www.malwarebytes.org get the free trial version its great.
May 07, 2009 | Microsoft Windows XP Professional With...
my computer has high speed internet but is so slow
1.Go to Start-> Run-> and type gpedit.msc
2. Expand the Administrative Templates branch
3. Expand the Network tab
4. Highlight QoS Packet Scheduler
5. Click on Limit Reservable Bandwidth and check the enabled box
6. Then Change the Bandwidth limit % to 0 %
Once you have done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
Nov 27, 2008 | Computers & Internet
148 people viewed this tip
David Payne
David Payne
