Tip & How-To about Refrigerators
Freezer won't Defrost - GE
This is a Common Problem specially in GE Refrigerators. There are lot of Complaints that, the Refrigerator Section is Working Perfect and it is ONLY the Freezer that won't Defrost.
We have Checked Defrost Heater and Thermostat and still Problem remains the same.On Old Models, you would Find Defrost Timer and in newer Models, Defrost Cycle is Controlled by Motherboard.
Bingo!! you are Correct. The motherboard is again a major Problem and there had many Recalls regarding the same in the past. I would advise you to Check Directly with GE regarding Recall for motherboard.
The other Symptoms of Motherboard Failure Could be :-
1. Dispenser Board Failure
2. Evaporator Fan Motor Failure.
Keep a check on it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Refrigerators Logo
High-pitched alarm-like sound coming from GE frig - TBX22PRYCRAA
Very common problem is the evap fan located in the freezer section is the cause. Sorry but this is controlled by the main board on the back and only way to fix the problem is with a new board. Sorry about the news but it is the problem.
May 31, 2010 | GE PFS22SISSS Stainless Steel French Door...
refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
we have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
617 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
