Tip & How-To about Computers & Internet
How to troubleshoot Drive Letter is not accessible error message
This is one of the most annoying problem that viruses leave behind. What actually happens is that the f-reaking virus disables your permission to access the drive. So once you have cleaned the virus Follow the steps below to access your permissions and change them. Note that you can only do this if you are logged in as the administrator.
1)Right-click on your drive and click properties.
2)Click on the security tab
3)Click on the Advanced button
4)Click on the owner tab
5)Click the edit button
6)Select administrators(if you want to allow only admins to access that files) or ALL users if you want to grant access to non-admins as well and then check the box replace owner on subcontainers and objects and click apply.
7)A message will pop-up asking you to confirm. Click Yes.
8)You will be notified that you have been allowed access. Close my computer and open it again and you should now be able to access it.
Thanks for reading :)
Computers & Internet Logo
windows cannot access specified device path or file
Windows cannot access the specified device path or file. You may not have appropriate permissions.What's annoying about this message is that sometimes it has nothing to do with permissions at all! Here's a couple of possible ways to fix it, depending on your system.
Note: First, restart your computer in Safe Mode (only XP and Vista) and see if you can open the file or programs in question. If so, it's not a "real" permission issue, it's a program or process on your computer that is giving the error.
The best solution that has worked for most people is to simply uninstall Internet Explorer enhanced security configuration.
Method 2 - Turn off anti-virus or firewall If you are having this issue in Windows XP or Windows Vista, then your problem is probably related to an actual permission issue.
Norton Internet 200X, Bitdefender, AVG anti-virus, Trend Micro 200X can all cause this problem. If you have any of these programs installed, make sure to disable them and test it you can run programs, open files, etc.
If so, then you'll have to either use a different program or find something on the Internet about to how to configure your software to not interact badly with Windows.
The same thing can also happen with an overly aggressive firewall. If you are running Comodo firewall or something similar (other than the basic Windows Firewall), then disable that also.
Method 3 - Unblock the file If neither of those two methods worked, the file may be blocked by Windows. Note that this is only for Windows Server 2003 and higher.
When you copy an EXE file from another computer to a Windows Server 2003 box, there is what is called a blocked property set on the file. This is due to the increased security on servers.
Right-click on the file and choose Properties. You'll see a button called Unblock at the bottom.
Method 4 - Real permissions issue Finally, you may actually have a permissions issue. In this case, make sure you are an Administrator or you are part of the Domain Admins group if you are in a domain.
Also, you can try right-clicking on the file and choose Run As. Then type in the Administrator credentials and try to run the file. If you are able to run it, that means you account is not setup properly or is not in the rightuser group.
Feb 09, 2014 | Microsoft Windows 7 Ultimate for PC
dell inspiron n5010,when i start up my laptop it take lot of time in starting up.and this problem i m facing from day one .its purchasing date :24/12/10
Does this happen when loading booting or loading windows? If this happens when loading windows, try disabling start programs and services.
press windows button, and then r
then type msconfig
press startup and then disable un-necessary programs that are starting up. leaving your anti virus.
also press services tap and hide all microsoft services, disable other services that you see there leaving your anti virus.
Jan 07, 2011 | Computers & Internet
why system restore is disabling automatically
u pc has been ifacted by virus that y this happen & when u give ctrl+alt+del then error come the task manager has been disbled by administartor u need a good antivirus software scan from it
Oct 24, 2008 | Microsoft Windows XP Professional
Toshiba Laptop - Antivirus 2009
This is known as a non intrusive advertisement trojan, a virus that antivirus companies are now using. These viruses will not do any damage to your machine, but they are very annoying. They are almost impossible to get rid, and here's why. When the virus is activated it places several copies of itself throughout the system. These copies lie dormant, which makes them hard to find, in areas or files that are considered safe by your antivirus, and aren't checked on a regular basis. Then when you get rid of the active virus, one or two more, but not all, will open leaving several more behind. After a few months the number is exponential. There are two ways of making the pop ups stop, but only one to be completely rid of it. 1- buy the product, pay on a monthly basis, and spend entirely too much money for what you're getting, and then have them come back if you cancel or miss a payment. 2- the only sure fire way to get rid of them is to wipe the hard drive, reformat, and install a new operating system. If you do this you will be rid of it, but you cannot back up anything. The virus hides in everything from pictures, music, video, screen savers, to registry files. Anything could be infected and bring the virus into the new system. I realize that this isn't what you want to hear, I've tried everything here at my shop for customers with this problem, and unfortunately, this is the only sure solution.
Jul 30, 2008 | Computers & Internet
476 people viewed this tip
David Payne
David Payne
