Tip & How-To about Televison & Video
How To Clean a LCD Screen , TV or Display
In this tip , I will be explaining how to clean your LCD screen. This information is applicable to camera screens , TV's and computer screens.
You will need
90% isopropyl alcohol
Water
Microfiber Cloths
10min of your time
#1 Go out and buy some microfiber cloths. They are available from most big stores at about $1-$1.50 each. Cut your cloth into smaller sections (about the size of a cigarette box) and save the rest for another cleaning.
#2 Mix your 90% isopropyl alcohol in a 50/50 ratio with water. I recommend you use surgical gloves as the alcohol may irritate your skin. This will be your cleaning solution. You will only need about two tablespoons full , so don't make too much.
#3 Take two of your microfiber cloths and dampen the one really well with your cleaning solution. There should be no fluid leaving the cloth if squeezed...otherwise , you have to much.
Now wipe your screen first with the damp cloth followed by the dry one and repeat once. This should leave your screen nice and streak , smudge and fingerprint free.
Remember to store the isopropyl alcohol in a safe place is it is poisonous and flammable and discard unused solution after use in the sink while running water with it.
Please remember to rate this solution if you found it helpful.
Kind Regards
Stephan
Televison & Video Logo
blue screen on play back of video
clean the heads of your video camera buddy !! use a cotton bud tip, with a touch (NOT SATURATED) of turps......an LCD screen cannot show bad tape speckle or white noise like the old vhs on a tv tube used too....remember when an old VHS Tape needed tracking?...thats what your camera is trying to tell you....but....it needs a clean as the LCD screen cannot show fuzz.....and waits for a good frame to display.....CLEAN THE VIDEO DRUM MATE !!
Jan 04, 2014 | Sony CCD-TRV228E Camcorder
clean lcd pc screen
With mine I always first use a computer air duster, Then I use a good clean micor fiber cloth with water and water only, polish lightly until dry and clean
Feb 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
e500 viewfinder does not display subject when tasking pix
Page 20 of your user manual manual explains about each time the INFO button is pressed while in shooting mode. The camera is not a live view LCD screen so after it shows you normal information and then detailed information if you press INFO button again the camera screen will shut itself off. To turn the screen on again you need to press INFO again. This is normal camera behavior.
Jan 01, 2009 | Olympus EVOLT E-500 Digital Camera
stains on the LCD monitor of Permanent marker
you could try mean green or totally awesome gotta love dollar tree. but be careful if you press too hard you could crack the screen or cause a pooling effect that may or may not go away. Oh or rubbing alc. last resort use liquid lighter fluid on a cloth.
May 22, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
255 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
