Tip & How-To about Cameras
Digital cams not functioning/frozen
Most digital cameras regardless of manufacturer have been known to stop functioning entirely. This is most often attributed to the fact that the battery contacts within the battery compartment have a film on them that must be cleaned. This is easily accomplished by "dampening" a cotton swab with rubbing alcohol and cleaning the contacts. Shortly after, blow into the compartment lightly to disperse any remaining fluid. This will solve your problem .
Cameras Logo
how many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
download entire user manual for 860is
The IXUS 860 is known in some parts of the world as the SD870. You can download the SD870 manual (and more) from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd870_is#BrochuresAndManuals
Feb 08, 2011 | Canon IXUS 860 IS Digital Camera
My Canon A80 just stopped taking pictures and displays all attempts as a black picture with no detail. everything appears to function normally as well as lense zooming, Could it be the sensor that is gone as it has not been dropped or subjected to water or moisture
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Dec 23, 2010 | Canon PowerShot A80 Digital Camera
Whats the difference between Canon EOAS 550D /Rebel / non rebel? Which is better camera?
Identical Canon models are sometimes marketed under different names in different parts of the world. Rebel cameras are known in America and EOS cameras are known in Europe. For example the EOS 550D is called Rebel T2i in America. They are in fact the same camera they just don't have the same name.
Nov 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
hello ..my focus function has stopped working..
no new camera is required, you have just changed the settings and it can be modified if you just calmly go through the manual given to you by the manufacturer.
Dec 01, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
206 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
