Home | All Products | EASYSHARE 5500 All-In-One InkJet Printer | Tips
Kodak AiO Home Center needs to be ran as Administrator
SDtester
By Wiz SDtester
Rank: Wiz
Rating: 87%, 115 votes
posted on Feb 27, 2008
Helpful
1. Right click the Kodak AiO Home Center icon and select 'Properties'
2. Select the 'Compatibility' tab
3. Make sure the 'Run as Administrator' box is checked
4. Select "OK"
Fix originaly posted by Airmack on this site
Thank Him.
Was this helpful?
Yes
No
6 people thought this was helpful
Comment #1
posted on May 22, 2009
jasg49
By Apprentice jasg49
Rank: Apprentice
Rating: 0%, 0 votes
You should not have to disable UAC or provide Admin credentials for this application (from a user acccount). It is a sloppy design that you can correct without making your system insecure.
Home Center triggers a UAC challenge because on EVERY startup, it atttempts to run its setup.exe to check for updates (It should have a menu item for this so YOU can control the check).
You can disable this check with a simple edit to the XML 'config' file used by AiO by following these steps:
1. Make sure you are logged in to an Administrator account.
2. Open C:\Program Files\Kodak\AiO\Center
3. Make a copy of the file 'AiOHomeCenter.exe.config' by right-click-dragging it to the desktop.
4. Rename the original 'AiOHomeCenter.exe.config' by adding .bck to its name.
5. Open Notepad.
6. Drag the Desktop copy of 'AiOHomeCenter.exe.confi to the Notepade window to edit it.
7. In Notepad, search for 'CheckForUpdateOnStartup'. Just below that line, you will see:
<value>True</value>
8. Change the value from 'True' to 'False'.
9. Save the file from Notepad
10. Drag the desktop copy back to C:\Program Files\Kodak\AiO\Center
If you encounter problems (you should not), simply delete the file and rename the .bck copy to get your original file back.
Comment #2
posted on May 05, 2008
shizz55
By Apprentice shizz55
Rank: Apprentice
Rating: 0%, 0 votes
there is NO 'Run as Administrator'
Comment #3
posted on Feb 29, 2008
houdy
By Apprentice houdy
Rank: Apprentice
Rating: 0%, 0 votes
thank you thank you thank you
Can you Help with these Printers problems?
Kodak EASYSHARE 5500 All-In-One InkJet...
print job cannot be completed to use advanced dot...
my printer was purchased on the internet after viewing...
My printer prints and makes copies. But it will not scan...
I need a phone number 2 call
test pages work ok no black when i print from pc
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
