Tip & How-To about Audio Players & Recorders
Reset 30 gig zune
If your zune locks up it is more than likely a bad music or sound file. the best way to unfreeze your 30 gig zune don't laugh it works by putting your zune in the freezer to clear memory and batery.
step1. put it in the freezer for 1 hr
step 2. remove from freezer and allow to come to room temp
step3. plug in and recharge fully
step 5. reload music on zune
New zune 8GB screen does not work
it seems as if something may have been attached badly on the inside that is a facttory problem is it still under warenty? if so i would send it back for a new one
Jan 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
says all 30 gigs are full, but no songs on Zune
you should try calling a product hotline and hopefully get it fixed but if that doesn't work then your computer probobly has something wrong with it. otherwise, you zune is busted. hope this helps.
Jun 24, 2008 | Microsoft Zune JS8-00001 Digital Media...
zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
music stops and zune freezes up
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
Feb 10, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
291 people viewed this tip
 Grubhead
Grubhead
