Tip & How-To about Cell Phones
How To Unlock BlackBerry Storm
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to Enter Unlock Codes on BlackBerry Storm (for Verizon, Telus & Bell STORM, see below)
1) Need a SIM card inserted into the phone
2) Click on manage connections, select turn all connections off
3) Go to Settings Menu, Options, Advanced Options and then SIM Card.
4) Hit the menu button and select show keyboard
5) Type in MEPD using the keyboard (nothing will show on screen)
0) You will see the Personalization screen, that show SIM> Disabled, Network> Active, Network Subset> Disabled
6) Type in MEP2 (Nothing will show on screen - use "Alt" to show numbers.) another screen pops up for the code.
7) Now it will say enter network mep code Enter the code that we send you, remember you ONLY have 10 chances to get it right
8) Press the enter key
9) A message will appear saying code accepted
00) On Personalization screen you will see the Network> Inactive.
10) Turn device off, insert SIM of your choice if have not done so already
11) Turn the phone back on
12) Go to Options, then Mobile Network, on the third row switch it to GSM/UMTS and you're done.
Issues:
1) If you have issues with the phone not recognizing the network, make sure the radio is on by making sure it is not low on power.
2) Sometimes the phone requires you to do "m e p p d" instead of "m e p d" and if that occurs, you will need to do "m e p p 2" instead of "m e p 2"
3) If you have issues with the network not working after you have finished and the phone isn't low on power, switch from Global to GSM to Verizon a few times (keep on doing) and after 3 times of the process completed, leave it on GSM. Should work now.
Removing "Activation Required" on the screen:
1) On the main screen of the phone, press ##000000
2) For the Mobile Directory Number, put in your phone number in there.
3) After you have done that, press the menu button to save the options and the phone will automatically restart
Cell Phones Logo
I completely locked my blackberry storm 9530 after entering BELL unlock code in a VERIZON. what is the solution ?? how can i unlock my phone usin a verizon unlock code?
Use unlock code to unlock your mobile....Get the unlock code here mobile-unlocker.com and get the following instruction here mobileunlockguide.com
1 - Switch ON your Blackberry Storm 9530 with its OROGINAL SIM Card.
2 - Go to Manage Connections.
3 - Click on Turn All Connections Off.
4 - Go to Options.
5 - Click on Status.
6 - (Input required info into Guarded Link to retrieve the unlock code)
7 - Go back to Options.
8 - Click on Advanced Options.
9 - Click on SIM Card.
10 - Type MEPD (letters will not appear on-screen but a menu will pop up).
11 - Type MEP2 (user will be prompted to enter MEP code).
12 - Enter the unlock code.
13 - Reboot your Blackberry Storm 9530.
14 - Go to Manage Connections.
15 - Click on Restore Connections.
16 - Blackberry Storm 9530 is now unlocked.
Aug 20, 2010 | RIM BlackBerry 7290
hi..i'm kaye..i would like to unlock my blackberry bold 9700 that was locked to Globe network Philippines. could you please give me my unlock code? or send it via email - kayedm1231@yahoo.com my IMEI # is: 359564.03.476291.6 thanks a lot
You can unlock any blackberry from any network & after unlocking you can use with any GSM provider around the world by just entering one time unlock code which is comes from server based on IMEI & unique code for every set.
Unlock 3-Hutchison Blackberry
Unlock Airtel Blackberry
Unlock AT&T Blackberry
Unlock Bell Blackberry
Unlock Cingular Blackberry
Unlock Claro Blackberry
Unlock Comcel Blackberry
Unlock Cable & Wireless Blackberry
Unlock Digicel Blackberry
Unlock Etisalat Blackberry
Unlock Fido Blackberry
Unlock Globalstar Blackberry
Unlock Movistar Blackberry
Unlock O2 Blackberry
Unlock Orange Blackberry
Unlock Rogers Blackberry
Unlock Sprint Blackberry
Unlock T-Mobile Blackberry
Unlock Telcel Blackberry
Unlock Tele2 Blackberry
Unlock Telus Blackberry
Unlock Verizon Blackberry
Unlock Virgin Blackberry
Unlock Vodafone Blackberry
Unlock 9900 Blackberry
Unlock 9700 Bold Blackberry
Unlock 9650 Blackberry
Unlock 9630 Tour Blackberry
Unlock 9600 Blackberry
Unlock 9550 Storm2 Blackberry
Unlock 9530 Storm Blackberry
Unlock 9520 Blackberry
Unlock 9500 Blackberry
Unlock 9300 Blackberry
Unlock 9100 Blackberry
Unlock 9000 Bold Blackberry
Unlock 8900 Curve Blackberry
Unlock 8830 Blackberry
Unlock 8820 Blackberry
Unlock 8810 Blackberry
Unlock 8800 Blackberry
Unlock 8700 Blackberry
Unlock 8520 Blackberry
Unlock 8500 Blackberry
Unlock 8350 Blackberry
Unlock 8330 Curve Blackberry
Unlock 8320 Curve Blackberry
Unlock 8310 Blackberry
Unlock 8300 Blackberry
Unlock 8230 Blackberry
Unlock 8220 Blackberry
Unlock 8120 Pearl Blackberry
Unlock 8110 Blackberry
Unlock 8100 Blackberry
Unlock Gemini Blackberry
Unlock Javelin Blackberry
Unlock Niagara Blackberry
Unlock Thunder Blackberry
Unlock Torch 9800 Blackberry
Aug 17, 2010 | Cell Phones
I'm trying to unlock my BB storm 9530,after I type "MEPPD" I enter "MEP2" or "MEPP2" but still I dont get any window to put the unlock code in,any ideas ?!
Before you start, you MUST have an Unauthorized Sim Card inserted. An unauthorized Sim Card is a Sim Card that is NOT belong to the provider of the phone. Example: If you have a Verizon phone, you need to insert a T-Mobile Sim Card inside the phone before turn it on. 1. Power on the phone.
2. Phone will said "MEP check failed. Do you want to enter MEP unlock code". Select Yes.
3. "Enter Network MEP code (# left)". Enter the unlock code.
4. Press Enter, you should see “Code Accepted”
5. You need to check Network Connection is set on GSM/UMTS. Menu>Manage Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once GSM/UMTS is selected. You can now ready to make phone call.
Notice: If the network not working after your phone is fully charged and unlocking process “Code Accepted”. You must change from Verizon CDMA network to GSM Global Network a few times, after change from Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global Network. Now it should work. (Verizon 8830 World Edition DOES NOT work in USA)
Mar 29, 2010 | RIM BlackBerry Storm 9530 Smartphone
How do i unlock my Blackberry Storm from verizon
hi
you need unlock code to unlock you mobile,
you can get unlock code easily
Let me you the Best site for getting unlock codes
the pre sales was excellent even after thepurchase there customer support was a+, you can check them here..
............Click Here
Dec 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
Bell Blackberry Storm 9530 network blocked how do I fix that?
i have a Bell Blackberry Storm 9530,igot the unlock code,but i enter it wrong 10 times,and i blocked the network,how can i fix that?please help me
Oct 03, 2009 | RIM BlackBerry Storm 9530 Smartphone
186 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
