Tip & How-To about Computers & Internet
How to avoid formatting your PC ?
Sometimes your Windows crashes or has corrupt system files & will not boot into windows. At this point, you may need to format PC or laptop (assuming you have tried all other options such as going into safe mode etc)
However if you don't have enough time or the CDs needed therefore no need to panic. I'll just tell you something having 80%+ chances to work.
You'll need another good working PC. Remove your affected Hard Disk, put it in another PC or plug it using an USB external casing.
Now, power on the PC. On booting the PC having the correct system will detect System errors etc... & recover,restore system files. If it doesn't correct the errors go to 'my computer/select the HDD/ properties/tools & check your HDD errors!
It'll be more than 80% chance that it works! I have tried it on many PCs & believe me it really helps.
Please send me your vote & feedback if you find it helpful.
Computers & Internet Logo
get error loading operating system
Try to enter in Safe Mode or boot from the original Windows CD
and set a system repair. Sometimes, sistem files are corrupted no matter why. So, in my opinion, boot from the original Windows CD
and then set a system repair or check for a Restore Point. Just in case. Good luck !
May 26, 2015 | ASUS Computers & Internet
can't get Toshiba Satellite L775 to boot past "windows is loading files" screen
I assume you are doing a System Restore/Recovery? Have you removed the HDD and tested it? Perhaps the Recovery files are corrupt/missing? A bit more info needed.
Jul 03, 2013 | Toshiba Satellite L655-S5160 Laptop PC...
what causes" ntldr"?
NTLDR fail is either corrupt files or a bad disk drive. Check my tip for how to repair software. If it is a hardware error, don't use the computer and get it to a local shop that can recover your data and replace your disk drive.
My tip: http://www.fixya.com/support/r6101870-windows_xp_failed_start_because_recent
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 02, 2010 | Dell Lattitude D600 Notebook
re-install windows
If you hit "delete" at start up (immediately before or after the beep)the computer will take you into BIOS. It could be a different key for your computer but it will tell you at start up. In BIOS, on the "boot" settings page there will be a "device order" list. Most computers from the last few years will have an option for "removable" device or "USB" device etc. YOU MUST PUT THAT DEVICE FIRST ON THE BOOT ORDER! I originally assumed that you already tried this, but the function is so standard that I have to point it out. OTHER OPTIONS -try an upgrade installation -copy the install cd to a booting hard drive partition (advanced) -pull out the hard drive and install windows on it in a separate computer. If you truly can't boot from an external device, than putting a new CD drive in seems like the most painless option... though I know thats not what you want! If it just a cd drive you need they come for about $10 nowadays. Food for thought anyway!
Aug 27, 2007 | Dell Latitude C640 Notebook
212 people viewed this tip
David Payne
David Payne
