Tip & How-To about Computers & Internet
Additional Logon Information required for wireless connection on Windows Vista
Many a times on your Vista wireless computer you might have experienced an error “Additional  Logon Information required” which is related to wireless connection. In such cases you need to manually add the wireless network settings on your Vista computer.
Please note that before you follow these steps please make sure to get information about your network name SSID and the type of security encryption being used on the network. If you are using a NETGEAR router then you can follow the steps as mentioned in the below link to check the required information:
http://www.fixya.com/support/r4095687-check_wireless_security_key_or
Perform the steps below on the concerned Vista computer to manually create a network profile:
1. Click on START menu and click on Control Panel.
2. Click on Classic View in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. Here you will see a list of networks and in that if you see any name in the list then please select the wireless network name and then click remove. Do it for every name that you see in the list.
5. Once the list is empty, click on ADD, and select the second option which is MANUALLY CREATE A NETWORK PROFILE.
6. Type the network name SSID exactly as you have on the wireless router. Please make sure that you have this name in the exact case as you have on the wireless router.
7. Select security type as per the security encryption type you have on your wireless router and enter the required password. Click Next and click close.
Reboot the computer and then check if you can access internet from your wireless connection.
Computers & Internet Logo
Wireless adapter problem
GO http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1310
Dec 30, 2011 | Trendnet TEW-664UB IEEE 802.11a/b/g IEEE...
I am getting Error Code 193 and then when I tried again, I got Error Code 999. I can not connect my router to my new laptop. Help. Dave
This article will guide user on what to do if could not connect to a wireless network using WEP. User encounters the following error message "Additional log on information is required to connect to this network" or "Validating Identity".
Instructions for Vista
Instructions for Windows XP
Instructions for Mac OS
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
my computer is restart automatically when i am on my work
This issue could be caused by any of the below possibilities.
  1. Software issue or error.
  2. Hardware issue or error.
  3. Heat related issue.
  4. Computer virus.
  5. Issue with operating system.
Answer:Software issue or error
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode. Additional information and help with getting into Safe Mode can be found on document CHSAFE.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
  1. From the desktop right-click on My Computer.
  2. Click the Properties option.
  3. In the System Properties window click the Advanced tab.
  4. In Advanced click the Settings button under Startup and Recovery.
  5. In the Startup and Recovery window uncheck the Automatically restart check box.
  6. Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors. Additional information about Device Manager can be found on our Device Manager page.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers. Additional information and help with computer drivers can be found on our drivers page.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer. Additional information about testing computers memory can be found on document CH000708.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date. Additional information about checking this can be found in document CH000533.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot, additional information about how hot your CPU should be running can be found on document CH000687.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
  1. Reboot the computer and enter CMOS setup as the computer is booting. If you are not familiar with how to enter CMOS please read through document CH000192.
  2. After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Jun 13, 2010 | Microsoft Windows XP Professional for PC
Accessing through a new computer
Is the new laptop xp? or vista?
for these two pc, you can use the built in utility of windows dor wireless conenction. There you will only be asked one information. The wep key/ security key/ passcode/ (they both mean the same anyway) this is available in the User interface of the router . This is sometimes called the set up page, that if you access this page...it will give you all the wireless settings. the best person to contact is your router manufacturer. That is this is still under warranty for free tech support.
Oct 11, 2007 | Blitzz Technology BWA711 (B3WL000900)...
812 people viewed this tip
David Payne
David Payne
