Tip & How-To about Televison & Video
Tv repair
Make sure before u work opn any t.v,u unplug the cord from the wall and m sure that there is no more power coming from the t.v.Make sure that u carefully remove the screws in the back as u lie the t.v on the front side of it.
Televison & Video Logo
we had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
I have an electric whirlpool range model RF368LXPQ. The stove and oven quit working but the clock still works.The day after it quit working I tried it again and a burner started to work. Once turned off it or any other burner or oven still does not heat up. Any ideas? Thanks
Maybe unplug your power cord from the wall and check the connections on the range. Ranges do not come with power cords attached on them. The installer has to put the cord on, maybe they didn't get the connections tight. While you have the cord unplugged it may be a good idea to check the power at you outlet in the wall and make sure you have 220 volts on it. You will need a volt meter to do this, be real careful not to touch the probes while checking this. Please rate my answer so I get points for it.
Jan 16, 2012 | Whirlpool RF367 Electric Kitchen Range
my xbox has a three light red ring
Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
Dec 29, 2010 | Microsoft Xbox 360 Console
my xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a few days i got back on and had the same problem there are no connection errors and its done tis continually this time i cant get it to come back on help please its almost christmas!!!!!!!
Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
Turning on i guess
It should work OK once you plug it back in. Note there are three places to check the power connection.
- The power pack has to be inserted firmly
- the cord that goes into the power pack
- the cord into the wall - be sure to check the wall outlet with a lamp or something to make sure it's not an overall power problem/breaker, etc.
Steve
Sep 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
227 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
