Tip & How-To about Computers & Internet
TOSHIBA BIOS PASSWORD REMOVAL DONGLE
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration. But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port. Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :- 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Computers & Internet Logo
how can i remove advent ert2250 bios password
Hello there,
To remove the bios password from you advent laptop, Power off the computer and make sure that it is unplugged. Open up your computer case. You need physical access to the motherboard to complete this procedure. Find a circular, (mostly) silver metallic object on the motherboard. This is the CMOS battery. CAREFULLY remove the CMOS battery and leave it out for about 120 seconds then put a piece of wire or metal between the battery contacts. This will remove the bios password stored.. This will flush the CMOS memory which stores the BIOS password and all other configuration. (See Warnings) Set the battery back into place and power on the computer. The computer should then warn you that the CMOS configuration could not be found. You can either reconfigure it yourself or restore defaults. Restoring the default configuration should be fine. You will notice that the BIOS password has been cleared and you can boot without it. You may reset the BIOS password to something else by going into the BIOS configuration and setting a new User Password (The Supervisor Password controls access to the BIOS, NOT the computer!)
All the best. Elect_Comp
Sep 13, 2011 | Dell Latitude D600 Notebook
how to remove bios password of L505 S5984 model laptop
The basic input/output system (BIOS) is essential computer motherboard firmware. Using the BIOS menu, you can configure many system settings--for instance, the computer boot sequence--and also configure hardware, such as optical (CD/DVD) drives or a monitor. An optional password protects BIOS from unauthorized access. However, you may need to remove the BIOS password to facilitate the configuration of your system. The Toshiba laptop model Satellite Pro T1000 allows you to change BIOS settings and remove the password with a special Windows hardware setup program. 1. Click "All Programs" from the Windows start menu.
2. Open the folder "TOSHIBA" and click on "Utilities."
3. Click on "HWSetup" to start the Toshiba Hardware BIOS utility.
4. Click on the tab "Password" in the HWSetup window.
5. Select the radio button "Not Registered" in the field "Password."
6. Click the "Apply" button to to remove the password and save that change in the laptop BIOS.
Please rate me if you find it very helpful.
Thank you very much. Good day ahead on you.
Aug 09, 2011 | Toshiba Satellite L505-S5966 Notebook
How to remove the cmos or bios password and want to remove the password in booting up, my laptop is toshiba satellite a135-s4527
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Mar 18, 2010 | Toshiba Satellite A135-S4527 Notebook
how i can remove Bios password from Toshiba
There is NO way that it can be fixed OTHER than returning it to the manufacturers or agent. They have proprietory Software Challenge Codes and this will do the job. However they cahrge for this usually around $125. Also one must provide proof of purchace and ownership. You can also find places online too, however they also cost.
Jan 26, 2010 | Toshiba Satellite A205-S5812 Notebook
i have a advent 7113 laptop and i have done everthing to get passed the bios password with no luck been at it for a week now and i think i am going to hit my son over the head with his laptop can any one help out there before i go nuts thanks
The BIOS Password is set from the BIOS configuration. Ask your son for the password. Once you have this password, you can enter the BIOS configuration and remove/disable this password.
Depending how old you computer is, removing the BIOS battery and main battery for 15+ mins may remove this password and restore the BIOS to the factory default (insert both batteries again) and configure the BIOS Date and Time etc.
BUT if the the password is stored on an EEPROM chip then removing will not fix this problem. There are no backdoor passwords available.
Nov 19, 2009 | Computers & Internet
681 people viewed this tip
David Payne
David Payne
