Tip & How-To about Audio Players & Recorders
How to replace your ipod battery
1. buy a new battery
2. open ipod (where it joins up) with thin pice of plastic or metal
3. there will be clips holding then together. push them in and they will open.
4. open ipod carefully because there a ribon cable holding each side together
5. carefully remove the hardrive, (should have a rubber protection around it) by lifting the cable socket.
6. removie battery carefully with thin plastic or metal. try not to touch the circuit board underneath.
7. disconnect wire from ipod case. (pull them from socket)
8. attatch the new battery
9. put back in hardrive
10. put case back on and your all set.
akai ewi 4000s neck strap mount
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
Apr 22, 2013 | Akai Ewi4000s Electronic Wind Instrument
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
my washer is make a ticking no the spin and i look at the bottom and white pices are on the floor
This is most likely a failure of the plastic couplers / rubber isolator between the motor and gearcase. This assembly is designed to fail during an overload condition, but they often just wear out over time. If you are mechanically inclined, it's not a difficult repair to make.
---UNPLUG THE WASHER FROM THE ELECTRICAL OUTLET---
1. Remove console
2. Remove 2 gold clips at rear of top
3. Unplug lid switch harness
4. Rotate the cabinet up a few inches at the rear and pull it straight off
5. Near the floor at the front of the machine, you'll see the pump, motor, gearcase assembly
6. Remove the 2 large metal clips that hold the motor to the gearcase (you might have to disconnect the motor wiring connectors
7. Rotate the motor / pump downward so the end of the motor facing the gearcase is pointing up / out so you can see it.
8. You should see evidence of a failed coupler... rubber and / or plastic pieces
9. Pry the broken plastic couplers off of the motor and gearcase along w/ whatever's left of the isolator (black rubber)
10. Install new parts (probably need to get these at your local appliance repair shop)
11. The tricky part is realigning the couplers and isolator so you can push everything back together. Be patient... once it's pushed back together, reinstall the large metal clips, motor wiring connectors, etc.
12. Put the cabinet back on, being careful that the rear corners are pushed inward so they engage on the base tabs
13. Install everything else in reverse order of removal
14. Plug it in and listen to her purr...
Good luck.
Feb 05, 2011 | Maytag PAV2300 Top Load Washer
98 Jeep Wrangler door handle won't open door
there is a metal bar inside that clips into the handle they come off all the time there is a plastic clip that hold the 2 together it most likely has fallen off and into the bottom of the door you can put it back together easily if clip cannot be found you can buy them at local parts store for a couple bucks..hope this helps
Nov 21, 2008 | 1998 Jeep Wrangler
how to replace a broken lcd screen
see the nokia e65 de-assembly video here.
http://www.youtube.com/watch?v=No2KPrG_QuM
Sep 08, 2007 | Nokia 7373 Cellular Phone
258 people viewed this tip
 Grubhead
Grubhead
