Tip & How-To about Computers & Internet
How to eject your CD/DVD rom
Sometimes a CD or DVD is put into the trey incorrectly, hence the trey will not open.
Here is how we fix this problem.
Take a sall pin, like a paper clip, push it into the small hole near the eject button.
While doing this, gently pull out the trey with the stuck cd.
You should be able to use your drive again.
Kind regards
Andrea
Computers & Internet Logo
dvd writer is not ejecting
PUT IN THE SMALL HOLE WITH NIDDLE OR PIN ON THE DVD/CD ROM DRIVE NEARLY EJECT BUTTON ,THAT 'S EASILY TO OPEN CD TRAY
Jun 28, 2012 | LG Computers & Internet
cd wont eject from cd slot
Hello
The link below should help you in force ejecting the CD/DVD which is stuck in the trey.
Click HERE.
Kind regards
Andrea
Aug 31, 2010 | Dell Studio 15 Notebook
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
The door will not open on my dv-5700a dvd rom drive.
Hallo
The reason for the trey not ejecting may be because there is a disc stuck in it from previous use. Now you need to force pen the trey. The way for doing this follows:
There should be a small hole in near the eject button.
Take a pin or small paper clip and push it into the hole.
When you feel a slight resistance, gently pull out the trey.
This will not damage the device, the small hole is made for this sole purpose. Really hope this can help.
Best regards
Oct 14, 2009 | NEC DV-5700A Internal DVD Drive
when I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
2,395 people viewed this tip
David Payne
David Payne
