Tip & How-To about Cell Phones
Connect to the internet.
Dear if you have a problem of connecting of internet by dial up modem.
So i can help you. if any number of you are using in your mobile phone.
and your phone display in the screen a error so please check the settings and call your cellular customer care. He can help you.If you have create a right setting of connect to you the internet.
if you can receive the internet settings please call the customer care and follow the instructions.
Cell Phones Logo
my samsung mobile is 'GT C3050C'. I install it pc studio, but I cannot use it by modem, I live in Bangladesh, I wanna to know it configuration,
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio.
Nov 21, 2010 | Samsung Modem Configuration Software...
I am using samsung 3g metro gt-s5350 with MTNL sim. I am able to surf the net on the mobile but not able to use it as modem for using internet for my laptop. It is showing "os error, remote device not connected" . Please help
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
Nov 08, 2010 | Samsung Modem Configuration Software...
I am using samsung gt-S5350 and tata docomo sim, I can access internet on my mobile but when i try to access internet through mobile on my lenevo laptop it gives "os error, remote device not connected" please help
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
Nov 01, 2010 | Samsung Modem Configuration Software...
my mobile is nokia 5800 music express. so i want to connect internet through my pc
First of all, install the Noki Pc suite on your computer, connect the phone in Nokia Mode, you'll see that your mobile is a Modem, Open the Internet Connection and set your nokia modem as the default modem, create a dial up connection using the Internet Connection wizard, you'll need the number to dial, this number is to be obtained from the Network Operator. Now you can connect to the internet using your phone. Note that the speed will be slow as compared to normal (wired/wireless) internet connection. Good luck Thanks for using FixYa.
Jun 01, 2010 | Nokia 5800 XpressMusic Smartphone
The power light and PC activity light are the only lights that come on. Send/Receive lights don't blink.
the most easy way to connect to the internet is get a bluetooth connetion (zippys) press the tools find device on the bluetooth on ur phone press pair device and press dial up inthe username put ur mobile number and password mobile number dial up number *99# dial
Apr 28, 2009 | Arris SURFboard SB5120 Modem
153 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
