Tip & How-To about Computers & Internet
Low Virtual Memory on PC
This is a little tricky but very easy to sole.
Your experiencing stalls, slow loading and WEB SITE NOT FOUND!
This is very bothersome in many ways. Please go to windows web site and type in Low Virtual Memory. You will be given a choice to use whatever site you wish including windows. Choose one and off you go. Just recently I had to do this and I had 1300 mis-placed files and much more.
Good Luck!
Computers & Internet Logo
bonaire vulcan summerbreeze evaporative Aircon
seems like your variable fan is faulty. If it is very slow, the coil inside ices up and no air can flow through the coil. It needs to be checked. To many tricky parts to remove with sensors in the way. very easy to break
Jan 30, 2014 | Heating & Cooling
slow starting
Run the software calibration for easy diagnostic, and fix it. Go under the HOOD motor follow the steps and proceed.
God bless you
Dec 05, 2013 | Sole Fitness Sole F63 Treadmill
farhanalio
There's something wrong with your Web site, but you don't know what. You've created a Web site and you want people to visit and read it, but for some reason no one's showing up. What could be wrong? Here are some common issues you might have with your Web site without even realizing it.
  1. No One Can Find Your Web Site - They're looking for a Web site just like yours. They go to the search engine and type in their keywords but your Web site is nowhere to be found.
  2. Your Web Pages Are Lost - They finally found your Web site and are looking for a specific Web page but try as they might, they can't find it.
  3. Web Pages Load Slow or Incorrectly - The reader found the Web page he wanted but it took forever to load or things are jumping around on the page while loading. Worse yet, the Web page loaded but it didn't load right.
  4. JavaScript Errors - You decided to add JavaScript to your Web page but you're getting an error.
  5. Text Too Large, Too Small - You want it to be just right. If the text is too small users with a high screen resolution, or bad eyesight, will have trouble reading it. If the text is too large people will have to scroll to read it.
    Use the Right Size
  6. Requiring Downloads - You added music or some other program to your Web site and it requires your readers to download software in order to view it but they don't have the software and don't want it.
    Use Software with Care
  7. Bad Spelling or Grammar - Your reader is reading your Web pages and notices that you're not a good speller or you often leave words out or your grame is just bad.
    Spelling and Grammar Fixes
Mar 21, 2011 | Computers & Internet
Kenmore 60 series will not spin or agitate
Common problem with these top loading Kenmore models.There are many step by step solutions on replacing whats called the motor coupling(3 pieces) An easy way to tell if this is your problem when you pull the washer out you may see a pile of black(or maybe even white) shavings right under the motor.The coupler keeps you from doing damage to the gearbox and breaks away first.It's a pretty easy repair if you follow the step by step instructions found on this site.(sorry I don't know how to linc for you) I just read a bunch of them and even found a couple that were on youtube showing video.The part is readily available on line or in my case at an appliance repair shop close to me.The hardest part of this repair for me was just getting the cover off first,but once again there are step by step instructions for that on here as well.The part is about 13-17 dollars,and it is a little tricky getting the one end on the gearbox,but take your time and follow the help full guides and it really isn't that bad.The cause for this problem seems to be first of all the material that the part is made of,but is mostly caused(from what i have been reading) is overlaoding of your washer.
Hope this helps,doing this repair is a whole lot cheaper than calling Sears
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
145 people viewed this tip
David Payne
David Payne
