Tip & How-To about Computers & Internet
Removing oversized icons and fonts on your Mac OS X Desktop (Mac OS X10.4 - 10.6)
Have you ever experienced your Mac desktop looking normal like this:
Then suddenly, your screen fills up your entire Desktop screen like this:
And when you scroll, it still looks like this?
What you are experiencing is an oversized screen, where every font and pixel on your monitor screen is blown way out of proportion.
So how can you get your Desktop back to normal like this?
Believe it or not, it is easier than you think.
What you will need to do is select System Preferences on your Dock or from the Apple menu icon:
* Select System Preferences on the Dock:
* OR locate the Apple Menu icon and select System Preferences from the drop down menu:
You are going to have to open System Preferences and select the "Universal Access" pane, which looks like this:
Click on it to launch the Universal Access page and make sure
you move your mouse around, in order to see rest of the window.
Now work down the oversized window and click the "Off" radio button under "Zoom:"
And just that fast... Back to normal view!
As you can see in this screen shot, all you had to do was turn off
the Zoom setting in Universal Access, in order to keep your screen from looking like this:
The Zoom feature is one of Apple's assistive devices for the visually impaired who actually need greater magnification in order to truly see, what is on their Desktop screen.
The Zoom feature can be triggered if the "On" radio button is turned on, or is the Zoom feature is on, BUT, has been reduced to normal magnification after this keyboard combination is pressed:
Apple Command Key + Option Key + the Plus (+) Key
(Which will enlarge the desktop screen with increasing magnification)
You can also click the Apple Command key + Option Key + the Minus(-) key, which will reduce the magnification back to normal view.
This feature comes in handy if you are sharing your Mac OS X Desktop with a loved one, friend or client, who may have a visual impairment or poor sight and you (in the kindness and consideration of your heart) have enable this Universal Access Zoom feature, for their convenience.
This of course will work out great for both of you, because now you know just how to reduce the magnification of your Desktop back to normal when it is your time on the Mac.
So now you know how to reduce that Oversized Super-sized screen issue on your Mac... it should not throw you for a loop the next time it should occur!
Thanks for viewing this Mac OS X tip from FixYa Support, I hope it will be of use to you one day!
Regards,
-Mactechtrainer
Computers & Internet Logo
what is mac error code-8003
If you are a Mac user then I know you have experienced this. You've been deleting files and your Trash Can is showing that there are items in it. You try to empty the trash and all of a sudden an error window appears. It probably looks something like this.
I share a link please visit and read it.
http://www.easypctutorials.com/how-to-fix-error-code-8003-os-x/
Thanks,
Apple Support
May 11, 2014 | Computers & Internet
How to install Apple Mac OSX in Normal Desktop ? I am not able to install Mac OSX in my Desktop so please help me with this issue
the mac os can be installed on the dual core processors or the prossers if you use the i3 or i5 processors it wont support for you . And also ther are a set of procedures to be followed to install mac in a normal desktop
Jun 13, 2011 | Apple OSX 10.3 for Unix, Mac
Hello, I have an X800XT Mac Edition graphics card with a G5 2.0 dual processor and the problem I'm having is that when I boot up my G5, it goes through the spinning weel process, but when it's finished and it's bout to launch the desktop, I get a blank screen n my 30" apple monitor. HELP! --Will
I am going to recommend a hardware approach first and then a software approach, to this issue, in order to assist you. At the end of these procedures, is a general support link from Apple for additional support for no picture in your iMac G5 display
I am seeing more of such display issues like this, and more often than not, if the problem does not have to do with the firmware, it may be a damaged or corrupted file which can hinder the iMac G5 from normal start up functionality.
PMU Reset (try this first)
The PMU (Power Management Unit) is a micro controller chip on the logic board that controls all power functions for your Mac.
• Shut down the computer.
• Unplug the computer's power cord.
• Press and hold the power button for 20 seconds.
• Release the power button.
• Attach the computers power cable.
• Press the power button to turn on the computer.
* Boot to your desktop.
This procedure may help but if it does not, follow the procedure below
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
One of these two procedures should help resolve the blank display issue you are experiencing,
Additional Support Link:
Apple Support iMac G5 - No picture on display
Regards,
-Mactechtrainer
Dec 11, 2009 | ATI Radeon X800 XT Mac Edition AGP Video...
OS X 10.4.10 Stuck Loop
H MerryAnn
I run Avid on my mac and have not experienced what you describe. Avid uses a lot of memory. The first thing I'd look at is do you have enough memory to run the OS and Avid. If that is OK check your screen res' (the system normally warns you if that is incorrect) If you have the install software try uninstalling and re-install to see if that helps.
It does not sound like a OS problem.
Regards
Paul
Aug 18, 2008 | Apple Mac OS X 10.4
desktop negative photo shot
Nobody is using your computer, so you don't have to worry about that. To change your computer back to normal hold down the Control, Option/Alt, Command, and "8" keys. This will change your desktop back to its normal state
Aug 03, 2008 | Apple iMac G5 Desktop
715 people viewed this tip
David Payne
David Payne
