Tip & How-To about Computers & Internet
How to make internet connection
For installing network....first of alll..load the lan driver.....and then go to my network places....and click on set a network connection...and follow the instruction....in windows xp u have to be little careful.....click on set up connection manually....and then fill up the details....and ur connection is set up
Computers & Internet Logo
hello i just format my old lab top thorhiba p200 16b and instaled a windows xp profersional fully updated but i cant connect to the internet i get no intenet gaetway and if i connet a lan cable i get nothing
go to"my network place" then "view all connections"...den see whether "local area connection" is appearing or nt....if nt dat means u dont ve LAN settings......so 1st get lan . den u will be able to explore de net. for more info see dis... http://www.youtube.com/watch?v=o-kKksYKHR8&feature=related
Mar 18, 2011 | Computers & Internet
My lan card drivers are not working. I have Intel D101GGC Motherboard. Please help in that problem. As soon as possible..
1st you check the Lan card driver is properly Installed.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Network Adapter
  • See the Lan Card Driver.if it is not available then Install the Lan Card Driver.
  • You can install driver from this site Lan Card Driver
  • If Lan Card Driver is Install then check It is disable from the network places in the control panel.
Mar 05, 2010 | Intel D101GGC Motherboard
I cannot connect to the network connections icon-nothing happens when I click on it? Therefore am unable to set up an internet connection
ok...first be sure that ya have all drivers for it ...and than choose the right connection type ...if its wireless fist be sure it is on ...and than open it ...if you are talking about the Lan connection ..get into the my network places ...choose the Lan ...right click and support ...than you will make the settings for the right network and protocol
auto for dsl ...and follow the ip ...for local area ...and static ip -es
but ...the most important is to have admin rights on our account and to have the correct drivers installed..
if you upgraded or downgraded into teh operating systems....chanddge the drivers to suit them
Nov 07, 2009 | Sony VAIO PCG-FRV27 Notebook
i recently got a router and the laptop is connecting fine how do i get my pc to connect wher would i get the disc to load the settings for wireless internet
You can either use the Ethernet (LAN) to connect the PC or you can use the wireless network.
Disc is no required to load the wireless setting in the PC. However you may have to load the Wireless Driver and Software for wireless card installed in your PC.
NOTE: If the PC is able to detect the Wireless Network then just select the wireless network and click on Connect to connect to the wireless network.
Good Luck!!!!!!!!!!!!!
Sep 22, 2009 | Computers & Internet
how to enable lan of intel board lan is not installed showing
If you are using a windows XP as an OS...make you have loaded all your drivers inclucing the LAN. Secondly from the START go the control panel--network and internet connections--network connections--you'll see the LAN icon/s.Right click on it and select Enable/Disable.
Jun 07, 2009 | Intel D845GVSR Motherboard
126 people viewed this tip
David Payne
David Payne
