Tip & How-To about Washing Machines
How to get your washer to work when it does not spin or drane
Go to the fillter at the front of the mashine and turn it to open, make sure mashine is turned off.put a bowl or plenty of towels down let the water drane out then clean the filter out.put it back in close it and away you go
Washing Machines Logo
Why are error codes F01, F06 and E2 showing up?
sounds like its not loading water.. this normally occurs if either your pump filter is obstructed or the inlet pipes filters are..TURN OFF THE POWER SURPLY then turn your water off at the stop valves and get the.. hold a small bolw under the joints when doing this as there will be some water in the pipes. with the pump filter id need to know the model to tell you where there filter is located, if your machine has a small panel at the bottom left of the front then its fairly easy if not the pump is at the back.
Click open the front panel you will see a knob similar to that on a mircowave,, turn this gently anticlockwise. ONLYT TURN IT SLOWLY as water will flow out, using a small bowl drain the water out. it will take a few bowl fulls to do this.. when your sure all the water is out fully remove the filter.. and run under a tap to clean of any lint etc, Before replacing put your finger in the outlet you will feel a small fan like device just move it slightly it should rotate freely.. (if not then the pump is jammed or burnt out) when replacing the filter double check for any dirt give it a rub with a sopf cloth and screw back in.. make sure it is in tightly..
Sep 03, 2014 | Maytag Maxima EcoConserve Series MHW6000X...
where will i find the fillter
there is a flap on the bottom right hand side make sure you unplug the machine and get a towel and a really small bowl and a big bowl right now you have pulled down the flap you have to turn very slowly the plastic screw put the towel down and the small bowl down and start to undo the screw keep undoing till all water has gone then take right out clear any thing in there then when done make sure its done up tight ok that's it hope i have helped you here is a video to help you ok http://www.youtube.com/watch?feature=player_detailpage&v=Q0TiugqnGbk
Nov 07, 2012 | Bosch Classixx WFL 2066 Front Load Washer
machine will not go into spin cycle and or drain
Mine was not draining the water out, so popped off the panel at front and checked the filter on the bottom right side, make sure you've plenty of towels down as it will let all of the water out of the drum! Unscrew the cover and check what's inside, I found several coins, matted hair and a plastic clothes tag.
Tried to spin the towels I used and my machine was back to full working order again. It's worth a try before you spend any money on parts!!
May 01, 2012 | Beko Washing Machines
water will not empty
your filter is blocked you have a fillter at the bottom right hand side take the flap down or if theres no flap its behind the kick plastic take off with care you then should see a black or white know you can twist make sure you have towels down as theres going to be a lot of water put a little bowl close to it and a bowl biger next to it that way you can empty it in the big bowl dont that the knob wight out do a bit by bit in till all water has stoped coming out thats it when you take it out look right in side you should have some thing in there...hope i have helped you please rate me
Oct 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
water doesnt drain,It keeps giving an error, and it makes a strange humming sound.
Hi.
Sounds like your drain pump has seized.
Ensure all water is drained from machine. This is not as easy as it sounds if full!!!
You may have to open door and bail most of it out. When this is done, pull out machine (two people needed) then tip the machine up 45 degrees. have a bowl and plenty of towels handy. Slowly open the drain pump filter, located behind the front plynth, and catch as much water as you can in a bowl. When water flow has stopped fully open the filer body and you will probably find a coin lodged in the pump impeller blades.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
149 people viewed this tip
Top Washing Machines Experts
