Tip & How-To about Video Game Consoles & Games
Bluray drive on PS3 does not accept discs after disassembling
This tip is for people who have already disassembled their Play Station 3 console and tried to replace the laser in the Blu ray optical drive.
If you replace the laser and then reassemble the Blu ray optical drive and the drive will no longer accept discs (like there is something blocking the disc) follow these steps to resolve.
(NOTE: if your PS3 is not accepting discs because the disc just won't push in, not like there is something solid blocking the drive, or your drive is making "grinding noises" refer to this tip: http://www.fixya.com/support/r4321102-bluray_drive_ps3_makes_grinding_noise )
Remove the metal casing of the Blu ray optical if you have not already done so. This requires removing the three black screws and the two silver screws on the bottom of the Blu ray optical drive.
With the metal casing removed, locate the 5 black screws on the top of the Blu ray optical drive to remove. There are two on either side and one at the back in the middle.
Keep the drive together for now (do not take the top off) and reattach to your Play Sation 3 console.
Turn on your PS3 and wait for it to power up.
Now, take the top of the Blu ray optical drive by “unfolding it” so the top of the drive rests on the PS3 power supply.
With the top off, hit the Eject button on the front of your PS3.
The drive gears should “pop” back into place.
Turn off your PS3 and reassemble the Blu ray drive. You should test your Blu ray drive first before reassembling the whole PS3.
Video Game Consoles & Games Logo
It won't play play station 3 games or blue ray movies
Hi there, it sounds like your blu ray laser has become faulty. Unfortunately this is a very common problem for the PS3 and there is not much that can be done about it. New lasers can be bought but they are difficult to fix. You could buy a new drive from somewhere like ebay at a cost of around £60. They are much easier to fit than the lasers themselves but you must make sure you keep the circuit board on your blu ray drive and swap it to the replacement drive as this is paired to the motherboard and will not work if it is not with the original motherboard.
Hope this helps and thanks for using FixYa
Sep 14, 2010 | Sony Playstation 3 (PS3) Console
play station will not read discs of any type
This is pretty much saying your Blu Ray laser has died. You will need either a new laser or a new drive, available from lots of places, however dont throw your Blu Ray drive away if you do replace it as you need the logic board that is on the drive.
Jul 28, 2010 | Sony Playstation 3 (PS3) Console
3,109 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
