Tip & How-To about Microsoft Office Outlook 2007: Windows
IMAP and POP settings for USA.NET email account
Here are the steps on how to configure Outlook 2007 to connect to your USA.NET account using POP3 or IMAP, please do the following:
* Click on Tools> Account Settings.
* Under the Account Settings window, click on the Email Tab, click New.
* Select Microsoft Exchange, POP, IMAP, or HTTP > click Next.
* Under the Auto Account Setup, place a check in the box called Manually Configure Server settings or additional types, click Next.
* Select Internet Email, click Next.
Next, fill out the following information:
* User Information
Your Name: Your Name (e.g., Joe Black)
Email Address: username@usa.net (e.g., jblack@usa.net)
* Server Information
Account Type: POP3 or IMAP
Incoming Mail Server: pop3.postoffice.net or imap.postoffice.net
Outgoing Mail Server: smtp.postoffice.net
* Logon Information
User Name: username@usa.net (e.g., jblack@usa.net - This must be your full email address)
Password: USA.NET password
Check the box remember password if you would like the system to remember your password. Please note: requiring your password to be entered each time you open Outlook will ensure your email is better protected and will prevent others from
accessing your email without your consent.
Click on the More Settings button.
* On Outgoing Server tab, check the box My outgoing server (SMTP) requires
authentication and confirm that the radio button Use the same settings as my incoming mail serveris selected.
* On the Advanced tab, choose the following settings:
Incoming server (POP3) > Place a checkmark in the box next to This server requires an encrypted connection (SSL) or Incoming server (IMAP) > Place a checkmark in the box next to This server requires an encrypted connection (SSL)
Outgoing server (SMTP)
Enter port number: 25, 2525 or 465
Use the following type of encrypted connection: Auto
* (For POP3accounts only) On Advanced tab, under Delivery, adjust the settings to meet your requirements.
Click OK. Finally click Next, and then click Finish.
Microsoft Office Outlook 2007: Windows Logo
How to configure msn pop3 settings for windows live mail?
Select your Outlook version and follow the instructions to change your Outlook account settings:
Microsoft Outlook 2013 Click here to view or hide detailed information about changing Outlook 2013 account settings
  1. In Outlook 2013, click on theFilemenu, and then clickAdd Account.
  2. Click to selectManual setup or additional server types, and then clickNext.
  3. Click to selectPOP or IMAP, and then clickNext.
  4. On the POP and IMAP Account Settings screen, type the following setting information:
    1. In theYour Namebox, type your name as you want it to be displayed to recipients.
    2. In theEmail Addressbox, type your email address. For example, typeyourusername@msn.com.
    3. InAccount Type, selectPOP3.
    4. In theIncoming mail serverbox, typepop3.live.com.
    5. In theOutgoing mail server (SMTP)box, typesmtp.live.com.
    6. In theUser Namebox, type your MSN account name.
    7. In thePasswordbox, type your MSN password.
    8. Click to select theRemember Passwordcheck box, if you want to save it.
    9. Leave theRequire logon using Secure Password Authentication (SPA)check box unchecked.
    10. ClickMore Settings.
    11. Click theOutgoing Servertab, and then click to select theMy outgoing server (SMTP) requires authenticationcheck box.
    12. Click theAdvancedtab, and then click to select theThis server requires an encrypted connection (SSL)check box underIncoming Server (POP3).
      NoteTheIncoming Server (POP3)box should be set to port 995.
    13. SelectTLSforUse the following type of encrypted connectionunderOutgoing server (SMTP), and then clickOK.
      NoteTheOutgoing Server (SMTP)box should be set to port 25. If port 25 is blocked in the network or by your ISP, you can set SMTP port to 587.
  5. On the right side of the POP and IMAP Account Settings screen, clickTest Account Settings.
    If you do not receive errors, your email account is set up correctly. Go to step 6.
    If you receive an error, make sure that you have entered all the information correctly, and then clickTest Account Settingsagain. If all the information is correct and you continue to receive errors, go to the "Next Steps" section for more help.
  6. ClickNext, and then clickFinish.
Microsoft Outlook 2007 Click here to view or hide detailed information about changing Outlook 2007 account settings
  1. In Outlook 2007, click on theToolsmenu, and then clickAccount Settings.
  2. Click theE-mailtab, and then clickNew.
  3. Click to selectMicrosoft Exchange, POP3, IMAP, or HTTP, and then clickNext.
  4. Click to select theManually configure server settings or additional server typescheck box, and then clickNext.
  5. Click to selectInternet E-mail, and then clickNext.
  6. On the Internet E-mail Settings screen, type the following setting information:
    2. In theE-mail Addressbox, type your email address. For example, typeyourusername@msn.com.
    12. Click theAdvancedtab, and then click to select theThis server requires an encrypted connection (SSL)check box under IncomingServer (POP3).
  7. On the right side of the Internet E-mail Settings scree, clickTest Account Settings.
    If you do not receive errors, your email account is set up correctly. Go to step 8.
  8. ClickNext, and then clickFinish.
Jan 20, 2017 | Computers & Internet
how to configure microsoft outlook 2007 for rediffmail
Follow the steps below to Setup Rediffmail in Outlook 2007
Open Outlook 2007
From the Tools menu - choose Accounts Settings.
From the Window under Email - Click the NEW button
Choose first option ( Microsoft Exchange, POP3, IMAP or HTTP and clik Next
Type your name in Name field
Type your rediff email address ( complete email id with @rediffmail.com ) and password and click Next button
The POP3 is pop.rediffmail.com and Outgoing mail (SMTP) type smtp.rediffmail.com
Click Next. In the Account Name box, type your Rediffmail address In the Password box, type your Rediffmail Password.
If you want Outlook Express to remember your password, check the Remember password box.
Do not check the boxes labelled Log on using Secure... Click Next. Click Finish.
To Receive Emails - Press the Send/Receive button on top
Nov 04, 2010 | Microsoft Office Outlook 2007: Windows
i cant get my bellsouth.net incoming mail or outgoing. had to set up my computer ater losing everything what do i put for my incoming mail server(pop, imap, http incoming mail pop, imap or http outgoing mail smtp server
Im assuming you are using outlook express, if not, I apologize, but steps should be similar for other types of software:
  1. On the Tools menu, click E-mail Accounts.
  2. Click Add a new e-mail account, and then click Next.
  3. Click POP3, and then click Next.
  4. Under User Information, do the following:
    1. In the Your Name box, type your full name the way that you want it to appear to other people.
    2. In the E-mail Address box, type your e-mail user name, followed by @bellsouth.net.
  5. Under Server Information, do the following:
    1. In the Incoming mail server (POP3) box, type mail.bellsouth.net.
    2. In the Outgoing mail server (SMTP) box, type mail.bellsouth.net.
  6. Under Logon Information, do the following:
    1. In the User Name box, type your full e-mail address, including the @bellsouth.net domain.
    2. In the Password box, type your password.
    3. Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer.
  1. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you are prompted to supply or correct it. Make sure your computer is connected to the Internet.
  2. Click More Settings.
  3. On the General tab, under Mail Account, type BellSouth.net.
  4. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  5. Select Use same settings as my incoming mail server, and then click OK.
  6. Click Next, and then click Finish.
Notes
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Unless specified by BellSouth.net, all server and address entries are typed in lowercase letters.
Good Luck!
Aug 10, 2010 | Computers & Internet
i cant receive my emails
You can't receive emails? You need to give more information. Are you using a Web mail (i.e. Yahoo mail, Gmail) or are you using an e-mail client (i.e. Outlook 2003/2007; Outlook Express)?
Email clients uses two types of account, POP3 and IMAP.
If you are using an e-mail client like Outlook 2003, you need to change the incoming mail server. Please follow the steps below:
For Outlook 2003/2007:
1. Open your Outlook and then click on Tools.
2. Go to Accounts or Email Accounts.
3. Go to Mail tab and you will see the account that you have created (like pop.gmail.com or imap.gmail.com)
4. Double-click on pop or imap account and then go to Advanced tab.
5. You will see the Incoming Mail server.
By default, the incoming mail server is set to 110, you may change it to 995 and then select SSL. Then close and reopen your Outlook and click the Send/Receive button.
Now, if you're just using a Web e-mail like Gmail or Yahoo mail, you need to check your storage. There's a possibility that you reached the quota storage of your email that's why you are not receiving emails. You need to contact your email provider for this problem.
If you have a router on your network, you need to check the router settings and perform a Port Forwarding. You have to open the port 110 or 995 so that you could receive e-mails.
These are the things that you need to check and consider.
Have a great day!
Jun 09, 2009 | Acer Computers & Internet
connecting my email to outlook express
Hi
Outlook Express doesn't accept web based email anymore.
I recommend Outlook 2007. You will also need to install the outlook connector to be able to do it.
Right now Outlook supports Hotmail web email addresses only.
In Outlook click on TOOLS and then ACCOUNT SETTINGS.
Click on NEW and choose the Microsoft Exchange,POP3, IMAP or HTTP.
Then just follow the On-Screen Instructions.
Don't tick the box where it says Manually configure server settings
cheers
Nov 06, 2008 | Computers & Internet
23,139 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
