Tip & How-To about Car Audio & Video
How to bypass the "Park Wire"
Ok, This simply requires that the "Park" Wire is either Earthed out, or Taken to +12 V. To be safe you should put a 1000 ohm resistor (This will limit any current to about 12mA, drawn, if wrong) in the line to stop any bad things happening, Tap on to the relevant, Eth, or Plus and see which one works.
Car Audio & Video Logo
car audio installation
Either that or it gets + 12 V DC, you need to connect a low value 1000 ohm resistor in series, and use that to check, if it;s earthed -ve or taken to + 12 V DC.
Mar 24, 2010 | Jensen's VM9312 Car DVD Player
How do you bypass the parking brake installation to play dvds without being in park
Well you get a resistor, 100 OHMS - 1000 OHMS or even, maybe a 12v light bulb, and connect it to either + 12 volts, or - Negative Earth, depending on how it is wired, and this will allow you to operate it...
Mar 06, 2010 | Pioneer AVH-5700DVD Car DVD Player
How can I have my in dash playing well i drive?
Using a 100 - 1000 OHM resistor, connect, the "Park Wire" connect it to either the - Earth, or + 12 Volts. One of them will enable it to work, usually it goes on the Park brake
Mar 02, 2010 | Car Audio & Video
AVX-P8DVD need to know how to bypass the parking break safty feature
Take the Park Wire, via a 100 - 1000 ohm resistor, to stop any potential damage if wrongly connected, AND this lead is taken, either to + 12 volts DC, always ON... or - 12V DC or Earth. Some also work through the Stop Lights Bulb resistance... But I am sure you get the idea.
Mar 02, 2010 | Pioneer Car DVD AVX-P8DVD - Premier 6.5"...
2010 Ford Nav system (DVD player)
Ok, This simply requires that the "Park"Wire is either Earthed out, or Taken to +12 V. To be safe you should put a 1000 ohm resistor (This will limit any current to about 12mA, drawn, if wrong) in the line to stop any bad things happening, Tap on to the relevant, Eth, or Plus and see which one works.
Feb 16, 2010 | Car Audio & Video
235 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
