Tip & How-To about Computers & Internet
How do I download "Whatever" to my "Whatever"
This is real simple instructions are the same for all. Get the Software and a USB cable. (It should have come with your device as standard) From Manufacturers Web Site for the software, download for free, and you will have to get, or buy, a suitable USB Cable to fit your EXACT device, whatever it is. Often you can buy "Bundles" of, a CD & Cable for very cheap. Now, after you get all this, you FIRST, install the software and reboot, NOW connect up your cable to PC & whatever it is, and then Turn it ON. The PC should "Beep" and it should be recognized, and it will install itself. After it finishes, Reboot, leaving your device plugged IN & ON. NOW you will be able to "RUN" the software that you installed, either from the START Menu, Or a Desktop shortcut, Start the software and set it up,usually you must set your USB port, usually it is the "Default" but make sure, Now you will be able to use the software to make whatever suitable to be put onto and taken off, from your device. Also most often once installed you will see your "Device" in "My Computer" as a "Drive", and as such, can you can, Copy, Paste, Cut, as you would on any other Folder/Drive. to work with files. MOST if not ALL Files of whatever, MUST be converted to a format your device will handle BEFORE you can put them onto your device and use them.
Computers & Internet Logo
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
tomtom instruction manual
Use the Standard USB to mini USB cable or the standard USB to micro USB cable that came in the box with the device.
Connect the stadard USB end to a USB port on the computer and the other end to the device.
In the car, connect the device to the cigaret lighter socket.
Nov 27, 2013 | GPS
how to conect the printer to the computer?
you will need an USB printer cable.
they don't always come with the printer. :(
Oct 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
stuck on USB display screen
U WON'T BE ABLE TO DO IT. U NEED TO DOWNLOAD THE SOFTWARE FIRST AND THEN FORMAT F: DRIVE. .
May 11, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Updating Garmin C330
You can use any standard USB cable to connect the PC to the StreetFinder as long as it fits.  Typically digital cameras have these cables.
Updated software can be found and downloaded from the Garmin website.
Oct 13, 2007 | Garmin StreetPilot C330 GPS Receiver
143 people viewed this tip
David Payne
David Payne
