Tip & How-To about Computers & Internet
0X7E Blue Screen error triggered by Microsoft KB977165 XP update and a malware infection
  1. Boot to your Windows XP CD, and enter the Recovery Console (HTTP://support.microsoft.com/kb/314058)
  2. Type the following command: CHDIR $NtUninstallKB977165@\spuninst then press
  3. Type: BATCH spuninst.txt and press
  4. Type: EXIT and press and the system will reboot.
  5. Go to HTTP://safety.live.com and run the full service scan to find/remove any rootkits found.
Computers & Internet Logo
Windows\system32\hal.dll. corrupt
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed:Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jan 19, 2013 | HP OmniBook XE3 Notebook
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
My 2 year old stepped on{or dropped } my Dell xps m140 and cracked the screen. I thought I would replace it myself..Before I do, I hooked up an external monitor to see if it still operates properly, well the windows Xp screen comes up but it will not boot all the way.? { Mother board? } Any suggestions
This error is also cause by the hard drive storage of your pc notebook, if you know how to locate the hard drive you just have to remove it for a while and then put it back, some loose connection of the hard drive cause the problem, if you find it still not working, you need to repair the system startup of Windown XP it is corrupted that's why it wont start.
Before attempting to check the physical parts of your notebook, try first to check and recover the Windows startup system.
In windows startup repair you can use the Windows Recovery Console.
Source: http://support.microsoft.com/kb/314058
Here's the step to start in Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
After you start the Windows Recovery Console, you receive the following message:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
1: C:\WINDOWS
Which Windows Installation would you like to log on to ?
(To cancel, press ENTER)
Enter the number for the appropriate Windows installation. In this example, you would press 1. Then, Windows prompts you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot be authenticated correctly. After you enter your password and the Windows Recovery Console starts, type Exit to restart the computer.
Use the fixboot command to repair the startup boot of your notebook.
Feb 01, 2010 | Dell Inspiron XPS M140 Notebook
I CNAT GET TO COMMAND PROMPT NEED TO GET INTO COMMAND PROMPT TO TRY TO BACKUP FILES ON BAD H.D.
Are you able to boot to Windows? What version of Windows?
If it's Windows 9x, go to Start > Run then type 'command' (without quotes)
If it's Windows NT/2000/XP, it's Start > Run then type 'cmd' (again, no quotes)
If it's Vista, type Command Prompt into the search box in the Start Menu.
If you can't boot and you just need a prompt, try booting your XP CD and when asked, select to repair using the Recovery Console.
Hope this helps!
Mar 28, 2009 | Computers & Internet
missing file or corrupt
Method 1 loadTOCNode(2, 'resolution'); Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 3 loadTOCNode(2, 'resolution');
uparrow.gifBack to the top Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Jun 23, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
228 people viewed this tip
David Payne
David Payne
