Tip & How-To about Audio Players & Recorders
How to save battery on ipod touch
To save your battery on your ipod touch... when your listening to music you have to push the button on the top and let it sleep why your music playss. so you can listen to music and save your battery
how to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
Mar 24, 2013 | Apple iPod touch
it has a locked in the screen
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off. This helps save battery life if you have it locked while it's asleep. It prevents your music from turning off if you've put your iPod in your pocket. However. it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right. Hope this helps.
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
how do i unlock an ipod touch when i do not remember the password
Unfortunately the only way to get into it is to erase all of the data. But on the bright side you should still have all of your music and apps saved to your computer so you shouldn't have any issues with putting all of you stuff back on.
You can check out this video:
And here are my directions:
  1. Plug your iPod into your your computer and turn it off. Make sure iTunes is closed.
  2. Hold the sleep button (on top) for 3 seconds.
  3. While holding the sleep button, hold the home button (on front) and the sleep button for 10 seconds.
  4. Let go of the sleep button and just hold the home button for up to 30 seconds or until you get a message that you will need to restore your iPod with iTunes before you can use it.
  5. After that restore your iPod to an older backup.
May 27, 2011 | Apple iPod touch
My ipod touch has a dark screen and doesn't show anything. no light at all as if it is turned off. but i can listen to music for example. it's working but there is no light.
  1. Turn iPod touch off and turn it on again.
  2. If the issue persists, try to reset the iPod touch while it is connected to power. To reset, press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge the device until it is fully charged.
  3. If that does not fix it. Connect to computer. Open Itunes and make sure you have the latest update.
May 04, 2011 | Computers & Internet
143 people viewed this tip
 Grubhead
Grubhead
