Tip & How-To about Televison & Video
Lcd tvs lines on screen
Lcd tvs with lines on screen.. unfortunetly it is usually the screen itself that is the problem
Televison & Video Logo
Black vertical line on the right side of screen. Color distortion on the right of that.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective panels to LCD TVs are given. You can see and compare it to that of your TVs'
Mar 13, 2014 | Mitsubishi LT-40148 40 in. LCD TV
line down screen
line down screen means usually the backboard of the monitor itself, is faulty, and needs replacing. unfortunately, need new monitor. if it's lcd, then possibly can be 'tuned' out using some settings 'fine' on the monitor itself.
Dec 09, 2013 | Element Electronics FLX3210 32 in. LCD TV
westinghouse tx-52F480s. flicker, turned into colored lines. now all black. all inputs. what is the problem. which board?
Most likely the T-CON board it is dead.The tv have colors vertical lines alway causes by a dead T-CON board,if only this problems,happen by the tv itself only.Not causes by u or an object by hitting it with forces,than the tv LCD screen panel it is damages and tv it is worthless as a whole tv set.Because the tvs LCD screen panels are very important to the tvs and it is 90% of the costes of all tvs.The T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 13, 2011 | Westinghouse TX-52F480S 52 in. LCD TV
vertical yellow block on right hand side of screen
That usually indicates a problem inside the monitor. It can be memory, driver or lcd panel connectors or a power problem. Unfortunetly this means it is heading to the shop. You should check for possibility of warrenty as well as checking the cost of replacement.
Nov 04, 2009 | LG Flatron 295LM 22" LCD Monitor
laptop screen
Your lcd probably went out, either that or the video card / chip on your motherboard. Usually it's the lcd itself though, occasionally it's the lcd cable but majority of time it's just the lcd itself. You can try using an external monitor to see if you still get a display from the laptop. If you do it points closer the lcd being the problem.
Feb 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
160 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
