Tip & How-To about Computers & Internet
How to Retrieve Shift-Deleted Items in Microsoft Outlook
A. ON THE CLIENT COMPUTER
REGISTRY EDITING
Warning: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Backup the registry first.
By default, the Recover Deleted Items functionality is only enabled on the Deleted Items folder in a user's private folders; items that are hard deleted cannot be recovered. To enable the Recover Deleted Items functionality on mail folders other than Deleted Items (for example, for Sent Items, Drafts, Outbox and Inbox folders), you must make the following changes to the registry:
1. Start Registry Editor (Regedt32.exe).
2. Locate and click the following key in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Exchange\Client\Options
3. On the Edit menu, click Add Value, and then add the following registry value:
Value name: DumpsterAlwaysOn
Data type: DWORD
Value data: 1
4. Quit Registry Editor.
On MS OUTLOOK
Select the MAILBOX folder, go to INBOX folder.
On the Tools menu, select Recover Deleted Items. (This option will not be available unless you are currently viewing the contents of your Deleted Items folder.)
From the pop-up window, click the message you want to recover. (Note that the date shown next to the message subject is the date that you emptied it from your Deleted Items folder, and not the date of the original message. To see the original message date, you may need to scroll to the right or expand the pop-up window.)
Click the Recover Selected Items button.
The items will be returned to your Deleted Items folder, and then you can move them to other folders.
Note: Deleted items are only available for recovery for a limited period which is based on IRRI exchange server retention policy configuration. You may check it with Kuya Boy.
B. FOR EXCHANGE SERVER ADMIN
CONFIGURING DELETED ITEM RECOVERY
Exchange Server Configuration
1. In the Exchange Server Administrator program, open the properties of the Private Information Store, and select the General tab.
2. Set the number of days that you want messages saved after they have been deleted.
NOTE: You can also set the messages not to be deleted until a backup has been done. You can override this by setting the retention time on individual mailboxes in the Properties for the mailbox by changing the
Deleted Items Retention time on the Limits tab.
Computers & Internet Logo
Installed itunes, now my disk driver isnt working. Sony viao laptop, vista home premium.
Follow this procedure to resolve the error if the optical drive is missing from Computer in the Microsoft Windows Vista operating system.
WARNING: There is a risk of data loss. This procedure involves editing the Registry. Using the Registry editor incorrectly can cause serious problems that may require the operating system to be reinstalled and can result in the potential loss of data.
NOTE: A backup of the registry can be created.
Click the Start button, and then in the search box, type regedit.
Press the Enter key.
NOTE: If prompted for an administrator password or a User Account Control prompt is displayed, type the appropriate password or click Continue.
In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
In the System folder, double-click the CurrentControlSet folder.
In the CurrentControlSet folder, double-click the Control folder.
In the Control folder, double-click the Class folder.
In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
In the right pane, click to select the UpperFilters registry value.
On the menu bar, click Edit.
In the Edit menu, click Delete.
In the Confirm Value Delete dialog box, click the Yes button.
In the right pane, click to select the LowerFilters registry value.
NOTE: Do not delete the UpperFiltersBak or LowerFiltersBak registry values.
Close the Registry Editor window.
Restart the computer.
Mar 27, 2011 | Matsushita Computers & Internet
hi i have windows xp the cd rom has has stoped working an erro code 41 comes up can you help thanks terry
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
To resolve this behavior, follow these steps:
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
Restart your computer.
Nov 04, 2009 | Microsoft Windows XP Home Edition
error 41 this is what i get when i trouble shoot
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk. ;)
Nov 01, 2009 | Samsung SC 140 (SC-140) Internal 40x...
windows xp does not recognize my cd driver since I have replaced my power supply, no disks play at all. control panel>device manager ..reads a code #41,..even tried to restart to an earlier date at no resolve!..do I need a new driver,or is it something that can be programmed? I currently have hp pavilion a815n w/dvd 630c driver.
Jan 31, 2009 | HP Pavilion a815n (PS512AA) PC Desktop
can not upload anything from the cd drive onto the computer
Dec 02, 2008 | Computers & Internet
149 people viewed this tip
David Payne
David Payne
