Tip & How-To about Video Game Consoles & Games
Disk stuck inside PS3 ? Try this.
1. Try turning the ps3 on and off and then hitting eject.
2. Do Not try to open up the playstation. You may do more damage than good.
3. Try to halfway insert another game, cd, or dvd into the playstation 3 and press eject.
4. Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game.
Video Game Consoles & Games Logo
a dvd is stuck and cant come out
try these: Try turning the ps3 on and off and then hitting eject.
Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBA Live out of the playstation.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
playstation 3 will not eject a disk
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
May 10, 2010 | Sony Playstation 3 (PS3) Console
I had a disc that would not eject. Held the eject button for ten seconds and it did finally eject but it will not accept discs now. I restored everything to default settings and im still having the issue.
• Rebuild Database2_bing.gif: Rebuilds the OS for the PLAYSTATION®3.
If the above steps still does not solve the problem, then I think will have to update your Ps32_bing.gif.
well as cookies.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 will light up green then yellow
4. Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBALive out of the playstation.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
ps3 problem
try ejecting it by going to the game logo on xmb press triangle and hit eject from there .....if that dont work turn it off then while turning it back on hit the eject button while its booting up (that works for PC's)
Hold down the eject button on the PS3 for like 10 seconds, and it will force eject it.
Did you try to restore default settings under system settings
here are a few solutions from http://uk.gamespot.com/pages/forums/show_msgs.php?topic_id=26017801
if you still have problems ejecting the disk and your console is under warranty then contact sony for further advise on repair or replacement
I hope this helps
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
243 people viewed this tip
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
