Tip & How-To about Video Game Consoles & Games
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
Video Game Consoles & Games Logo
my xbox 360 picher will not show on the tv how can i fix it and the conteroler will not stop blincking
Try this first
Same procedures for an xbox
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
then try
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
Jan 20, 2011 | Microsoft Xbox 360 Wireless Controller
how to connect a tv to a wii
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
Disk not working
Unplug all connections from the Wii, Tv, and electrical outlets. Wait an hour or 2 then hook everything back up and it should work.
Aug 24, 2008 | Nintendo Wii Console
393 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
