Tip & How-To about Video Game Consoles & Games
How to fix your PS3 when the hard drive disk is corrupt.
Put your PS3 in Standby Mode.
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
Connect controller to PS3 screen. You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
Safe Mode options screen. You will then see this screen.
-REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step.
You will then see a screen. "The hard disk's file system is corrupt and will be restored."
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Video Game Consoles & Games Logo
Hi there, I want to know, my PS3 slim is updated with v3.60 but my hardisk is corrupted, so yesterday I have try put my friend hardisk (v3.55 installed with multiman) on my PS3, but no display when ON. Then I put back my hardisk, also no display, I have try the soft reset method and recovery method, but not working, any suggestion?
Follow the below procedures if the hard disk of your PS3 is defective;
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
I hope this helps...
Regards.
May 04, 2011 | Sony Playstation 3 (PS3) Console
my ps3 doesn't even have an options when I start it, it only says cannot start, correct hard disk cannot be found, what do I do?
Try this:
Good luck.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
hi my hard disk's file system is corruped how can i fix it?
Connect controller to PS3 screen.You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen.You will then see this screen. Safe Mode options screen
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
306 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
