Tip & How-To about Computers & Internet
Unlocking huawei USB modem
You can get rid of the network and can use any network on your huawei USB modem, For unlocking request send the following detail. ---------------------------------------------------------------- IMEI - xxxxxxxxxxxxxxx Model - eg162g
your e-mail address country -----------------------------------------------------------------
to email anas@indiamail.com or follow the website
https://www.blogger.com/comment.g?blogID=3030864710776204821&postID=4306924191430386367
Computers & Internet Logo
PLEASE help unlock my device E5331s-2 IMEI::860667017553111
Hi. You can unlock your Huawei E5331S-2 safer and easier using unlock code. You can get the unlock code for a Huawei E5331S-2 from SimpleUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
If your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Jul 14, 2014 | Huawei Unlocked E5331 Wireless Hspa 21m...
unlock huawei E353Tu-6 mobem
HUAWEI E353 TU-6 and Huawei E353 are same modem...You can Unlock it using the Unlock Code...Visit the site Prounlocking.com/huawei-modem-unlocking-service/rs8wp10/ get the Unlocking service for your HUAWEI modem and unlock it from service provider lock.Follow the instructions below and unlock it step by step...
Method 1:
and press enter.
Method 2:
6.Click on the Send AT Command button and make sure you get the response"OK".
Oct 12, 2012 | T-Mobile Huawei T-Mobile Webconnect USB...
UNLOCK CODE FOR USB MODEM HUAWEI EG162G
I have idea usb net setter modem - Huawei EG162G. Please help me to unlock it so that i can use any other network sim in it.
Please send me the unlock code to unlock this data card.
IMEI No. is 353474021272299
Jan 15, 2010 | Computers & Internet
i have idea netsetter huawei EG162G MODEM its work with idea sim only can some unlock its to use other operator its imei no is 353474027400605 and sreril no is D82AA12921300854 PLZ REPLY THANKS
EG162G usb modem.my IMEI no is: 353474027386069 & s.no.: D82AA10921300899. i have idea net setter HUAWEI. but i want to use other network. but when i put ohter sim card so ask 10 digite unlock code. please help me and give me code for unlock it.
Jun 11, 2009 | Computers & Internet
110 people viewed this tip
David Payne
David Payne
