Tip & How-To about Computers & Internet
Activate the Faunhofer IIS MP3 Professional Codec remove Advanced
The WMP Bundled MP3 codec is the L3CODECA.ACM encoder "Fraunhofer Advanced MPEG" codec has limitations on available bit-rates andkeeps the sampling rate at below 22,050Khz it is licensed by Microsoft and ACM (Audio Compression Manager) is also by Microsoft
To improve the bitrates and sample rates available to you install and activate the Professional Fraunhofer ACM codec this is called L3CODECP.ACM, use the included TWEAK to remove the Advanced version and enable the Professional version after you have installed it.
The another version of the Fraunhofer MP3 codec is L3CODECX.ACM, and is a decode version ONLY and can be seen in the drivers.desc in the registry this can't be used as an ACM for re-encoding in VirtualDub and other such programs. This is also included in the zip file HERE
If you want to remove the MP3 decoder only L3CODECX.ACM I suggest that you use Codec Sniper be carefull only DELETE press once keep your sound ON if it says HEADSHOT it has been removed....
Check with Sherlock Detective to see if the Codec has been removed sucessfully this is also the best way to view all your Audio and Video codecs it will give you version number and manufacture details
  • l3codecx.acm: v1.0.0.64 (included in WMP6.4 decode only)
  • l3codeca.acm v1.9.0.305 (Advanced): Encodes up to 56Kbps
  • l3codecp.acm v3.4.0.0 (Professional): Encodes up to 320Kbps. (included in WMP10+11)
  • l3codecp.acm (so-called "Radium" version): Encodes up to 320Kbps
If you want to extract this latest L3CODECP.ACM v3.4.0.0 that has unlimited encoding use this little tip its perfectly legal to do this by the way.
Download the wmp11-windowsxp-x86-enu.exe it may require Windows Genuine Activation then save it to the root folder then extact it the Professional Version of the Codec L3CODECP.ACM, will be included in the wmp11.exe extract this and then just copy it to the system32 folder use THIS reg tweak to install it.
Computers & Internet Logo
Windows 7 Media Player 12.0.7601.17514 configuration setting are corrupted and remain corrupted after resetting the Media Player to its default settings. How do I completely rebuild the default Media
You may be able to remove then put back WMP from Programs and Features in Control Panel. Click on add/remove features and you should see it there. Uncheck the box and apply. Restart afterwards then check the box and apply. May require another reboot.
Jan 14, 2013 | Microsoft Windows 7 Home Premium 64BIT...
what videos can it play?
Any videos that are in the proper format.
Download and install the "Sansa Firmware Updater", connect your Fuze, and run the Updater. Besides making sure that your Fuze has the most up-to-date firmware, it'll allow you to download the "Sansa Media Converter", which can convert most videos directly onto your Fuze in a format that it can play.
Jan 27, 2010 | SanDisk Sansa Fuze MP3 Player
how to install mp3 in a v3i cellular phone?
On your PC if you go into Start/Settings/Control panel/Sounds and Audio devices, under Hardware tab/Audio codecs, click Properties, you'll see the driver listed as "Fraunhofer IIS MPEG Layer-3 codec (decode only)". This confirms that the wrong driver is installed.
Something you installed, probably to burn CDs, installed a playback-only version of the driver. The driver is l3codeca.acm, which is replaced by the playback-only version l3codecx.acm.
You need to edit the Registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32. Locate the item named msacm.l3acm.
Its value should be changed from l3codecx.acm to l3codeca.acm.
Note that you might have to use the full path name thus:
C:\WINDOWS\system32\l3codeca.acm
For its name to appear properly in the Audio codecs list.
If that's not your problem, and you want to tranfer files to and from Mob/PC.
Go here to learn more:
http://www.knowyourmobile.com/motorola/motorolarazrv3i/motorolarazrv3iuserguides/167/backing_up_your_motorola_v3i_to_a_pc_by_bluetooth_or_sync.html
Mar 31, 2008 | Motorola Mobility RAZR V3i Cellular Phone
3,174 people viewed this tip
David Payne
David Payne
