Tip & How-To about Computers & Internet
USB PORT FIX WIN 7
Method 1
*For Microsoft Windows Vista (and windows 7) Click Start, and type device manager in the Start Search box. Click Device Manager in the Programs list. If you are prompted for an administrator password or confirmation, type your password or click Continue. In the Device Manager dialog box, expand Universal Serial Bus controllers. Right-click USB Root Hub and then click Properties. In the USB Root Hub Properties dialog box, click the Power Management tab. Remove the check from the Allow the computer to turn off this device to save power check box. Repeat steps 1 through 4 for each USB Root Hub listed in the Device Manager.
Under Power settings, check the 'USB settings' -> 'USB selective suspend settings' and make sure it is disabled.
Check Thumbnail, highlighted: Open Device manager, Double click on Universal Serial Bus controller at the bottom, Double Click USB Root Hub, Click Power Management on top right, Uncheck Allow Power...
Method 2
*You can disable the USB Selective Suspend feature as a workaround by editing the registry. The USB device may become unresponsive because of a race condition in the Selective Suspend feature. The Selective Suspend feature suspends the USB device to efficiently maintain battery power by enabling the computer to turn off the USB device. However, sometimes this feature may not correctly wake up the USB device. Therefore, the USB device is unresponsive when you try to use it. You might want to disable this feature for server products where power management is not important or required. *To disable the Selective Suspend feature, follow these steps: Click Start and then click Run. Note If you are running Windows Vista, click Start, and then use the Start Search box. Type reedit, and then click OK. Registry Editor opens. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\USB If the DisableSelectiveSuspend registry entry is present, double-click it. If it is not present, create the entry. To create the entry, follow these steps: On the Edit menu, point to New, and then click DWORD. Type DisableSelectiveSuspend, and then press ENTER. On the Edit menu, click Modify. In the Value data field, type 1 to disable the Selective Suspend feature, and then click OK.
Computers & Internet Logo
why the windows7 cannot recognize the usb cable device of psvita
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
how to install my web cam
Method 1: Update the LifeCam drivers in Device Manager
  1. Open Device Manager.
    • In Windows Vista or Windows 7, click Start vistastartbutton.jpg, type devmgmt.msc in the Start Search box, and then press ENTER.
      securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
    • In Windows XP, click Start, click Run, type devmgmt.msc, and then click OK.
  2. Expand the following entries:
    • Sound, video , and game controllers
    • Imaging Devices
  3. Look for a black exclamation point (!) on a yellow field next to a device. The exclamation point indicates that the device has a problem. Right-click the device, and then click the option that corresponds to your version of Windows:
    • In Windows Vista, follow these steps:
      1. Click Update Driver Software.
      2. Click Browse my computer for driver software.
      3. Click Browse.
      4. In the Browse For Folder dialog box, move to the following folder and then click OK: C:\Program Files\Microsoft LifeCam\Driver32 If a driver is not found, try the following folders: C:\Windows\System32\Drivers C:\Windows\Inf
      5. Click Next.
    • In Windows XP, follow these steps:
      1. Click Update Driver.
      2. Click Install from a list or specific location (Advanced), and then click Next.
      3. Click to select the Include this location in the search check box, and then click Browse.
      5. Click Next.
Method 2: Download and install the latest software To download the most recent version of the LifeCam software, follow these steps:
  1. Visit the following Microsoft Hardware Web site: http://www.microsoft.com/hardware/downloads/default.mspx
  2. Click Software for Microsoft internet communications (webcam and headset) products.
  3. In the Select type of product box, select Webcams.
  4. In the Select your product box, select your LifeCam product.
  5. In the Select your operating system box, select your version of Windows.
  6. In the Select your operating system language box, select your Windows language.
  7. Click Go.
  8. Click the link to download the most recent version of the LifeCam software.
Courtesy Microsoft.com
Jul 15, 2011 | Microsoft LifeCam VX-1000 Webcam
Hi, My computer does not detect my CD PCL-350KM webcam with headset. What can I do?
This problem can occur if:
(1) You previously installed a Logitech Webcam.
(2) The LifeCam drivers are installed incorrectly.
Solution:
In Windows Vista, click Start , type devmgmt.msc in the Start Search box, and then press ENTER.
Imaging Devices
Click Browse.
C:\Windows\Inf
Click Next.
C:\Windows\Inf
Click Next.
http://www.microsoft.com/hardware/downlo...
Click Go.
Microsoft knowledge bank.
Mar 14, 2011 | Cameras
hola tengo un problema con micamara microsoft por que perdi el disco
Chris ThrashB52Computers
Method 1: Update the LifeCam drivers in Device Manager loadTOCNode(2, 'resolution');
    • In Windows Vista or Windows 7, click Start Collapse this imageExpand this imagevistastartbutton.jpg, type devmgmt.msc in the Start Search box, and then press ENTER.
      Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
    • Imaging Devices
      3. Click Browse.
      5. Click Next.
      5. Click Next.
Jan 11, 2011 | Microsoft LifeCam VX-1000 Webcam
584 people viewed this tip
David Payne
David Payne
