Tip & How-To about Computers & Internet
Speed Up Windows XP Boot and Shutdown Times
This guide will show you how to shorten the time it takes for your desktop to appear when you turn your computer, and make it shut down faster as well. Here are a few tips to get you right to your desktop as quickly as possible after startup.
To speed up Windows XP shutdown times:
Turn off services that you don’t need. If you want XP to shutdown faster, you need to have less services running for it to shutdown. Disable any unneeded services.
Don’t clear virtual memory at shutdown. Clearing the page file can provide more security, but that comes at the expense of speed. I don’t really care if someone can look at my page file. If you are more concerned with the shutdown speed, then you will want to disable this option in the registry. You will need to locate the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management registry key and change the ClearPageFileAtShutdown to 0.
To speed up Windows XP Startup times:
Waiting for your computer to boot can be a painful process. Though Microsoft has taken steps to speed up the boot process, it still can be improved. Here a few suggestions you can follow to speed up your Windows XP boot time.
Boot Defrag. If your boot files are closer together it will take less time for your hard drive to seek the files, therefore giving you a faster boot time. This was enabled by default on my machine, but you will want to make sure you have the option enabled in the registry. In HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction
You will want to set “enable” to “Y”.
Keep the registry clean. Windows registry can be a disaster. When programs install they will create registry keys. When you uninstall the program it will leave behind useless registry keys. The solution is to use a good, reliable, registry cleaner. Be careful in which one you choose though because a bad cleaner could really screw up your system. My favorite choice is CClceaner, which will also rid your machine of some spyware and temporary internet files. You can download it here.
Change BIOS Settings. The computer has to go through the BIOS before actually touching Windows. Changing a few settings can decrease the time it takes to actually get to the Windows XP boot screen. First you will want to run a Quick POST (power on self test) if your bios has this option. Secondly you will want to disable booting from a floppy (especially slow), cd, usb. If the BIOS only has to look for the hard drive it will go much faster. You will want to remember that you changed this setting though, incase you have to boot from one of these devices for troubleshooting. The last option is to turn off Boot Delay if you BIOS has this available.
01011010 G.I.G hacker 0100101
www.gighacker.blogspot.com
Computers & Internet Logo
reset bios
Installing a fresh operating system is a good option, and there might be a feature in the BIOS to restore the system to factory defaults. Information on how to do this:
Windows XP: Dell PC Restore
Using PC Restore:
1. Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top
of the screen.
2. Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish
starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot.
3. Click Restore and click Confirm.
The restore process takes approximately 6 to 10 minutes to complete.
4. When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer
completely reboot.
5. When prompted, click Yes.
The computer restarts.
Because the computer is restored to its original
operating state, the screens that appear, such as the End User License
Agreement, are the same ones that appeared the first time the computer
was turned on.
6. Click Next.
The System Restore screen appears and the computer restarts.
7. After the computer restarts, click OK.
or
http://www.user-guides.co.uk/download/dell/delloptiplex/dell-optiplex-330-reset-bios-password.html
Aug 18, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
lost password cant get in is there some way of reseting the comp?
Actually there is.....
  1. Reset your computer and continuously press f8. This will bring to a list of choices then choose safe mode.
  2. Safe mode will show you a couple of log in ID's if you have your own log in ID in your PC. It will show an ID named Administrator enter this account.
  3. Go to control panel then choose user accounts.
  4. Create your won ID and make it admin or delete a password from other accounts.
This is the first guide, in some computer the second guide can be done.
  1. Open your CPU tower case and locate a round shape battery.
  2. Remember to do this with your computer shut down.
  3. Remove the battery and turn your computer on.
  4. Shut it down again then reinstall the battery.
  5. When you turn your PC on it will automaticlly disable all passwords.
3rd guide
  1. Follow the step 1 in guide 2.
  2. Near the Battery is a 3 pin with a binding blue clip binding the two pins and leaving one pin.
  3. Remove the pin and bind the other two. Like this......123 <--pins, 1 and 2 is bind then remove the clip and bind 2 and 3.
  4. Turn your computer on and the passwords will be gone.
  5. Remember that the pins near the battery has a color blue clip.
IF you have comments and questions, feel free to update this post.
Apr 22, 2010 | HP Compaq Business Desktop d330
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
laptop not goes shutdown
get a program called tweakui and tell it to shut down you computer faster.
Apr 21, 2009 | Computers & Internet
220 people viewed this tip
David Payne
David Payne
