Tip & How-To about Video Game Consoles & Games
How to format PS2 memory Card for use.
Insert the PS2 memory card into the first memory card slot on your Playstation 2. Make sure that the card is all the way in the slot the card may not register when you turn on your Playstation 2.
Turn on the Playstation with no game or DVD inside of it. Wait for the main menu to pop up on your television screen.
Using your PS2 controller, highlight the memory card option and press the X button. This will open up the memory card menu, which will allow you to delete data or transfer data from one memory card to another.
Wait for the Playstation 2 to send you a prompt asking you to format your new memory card.
Click "Yes" when the formatting prompt appears on the screen. This will automatically format and set up your new memory card for use with your
Video Game Consoles & Games Logo
My memory card slot 1(PS2) does not read cards but slot 2 does?
take out slot one memory card and insert your second memory card into it (they are supposed to use slot 1)
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
playstation 2 does not detect memory card
YOUR MEMORY CARD SLOT DEFECTED. REPAIR IT
IF HELPFUL THEN RATE
Jul 10, 2009 | Sony PlayStation 2 (PS2) Console
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
PS2 doesn't acknowledge memory card in memory card slot 1
make sure that theres nothing blocking the mem slot 1.
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
1,243 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
